Front Wheel Stud Spinning - HELP! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-31-2000, 12:09 AM Thread Starter
I bought a Samurai and was going to inspect the brakes to make sure everything was up to par. When I tried to loosen a front lug nut the stud started spinning. I tried using some WD-40 to free the nut but it ends up making the stud spin even more. My next step is probably to go buy a nut spliter to break the lug nut off. Has any one ever replaced a front wheel stud before? Is it a simple job or do you have to remove the axle? I have replaced one on a front wheel drive Pontiac and i took forever to get the axle out enough to press the stud in from the back. Is a Samurai easier? I looked in a Haynes book and it doesn't cover it. I think I am going to buy a Suzuki shop manual as soon as I can find one.
zoomy4 is offline
post #2 of (permalink) Old 08-31-2000, 05:10 AM
zooky's Avatar
Re: Front Wheel Stud Spinning - HELP!
just remove the wheel with the spindle still attached and you can get to the back of the stud. Just remove the big nut that holds it on to the axle and the whole thing will come right off, then tack weld the stud to keep it from rotating, then, while you are there, repack the bearings.
zooky is offline
post #3 of (permalink) Old 08-31-2000, 07:14 AM Thread Starter
I see what you are talking about... remove the spindle nut underneath the hub and pull the whole rotor/caliper assembly off of the spindle. Cool, but will I be able to get to the back of the wheel stud with the backing plate still in place? Any addition help would be great.
zoomy4 is offline
post #4 of (permalink) Old 08-31-2000, 07:36 AM
mike shannon
you can change the stud with out pulling any thing off. my buddies samurai had three spinning on one side and two spinning on the other.had to burn them off with a torch,no big deal.just get the wheel off and rotate the the bad stud to the top.and knock it out and replace it with a new one use a lug nut and washers to pull it in.it will more than likely need the stud tack welded in because the spinning stud normally cuts out the flat that is there to hold it.don't go crazy with the welder just a little tack.hope this helps mike
88ht,two87s,88.5 spoa,33X12.50,5.12 f&r,rock cage,4.16 T case
post #5 of (permalink) Old 08-31-2000, 07:56 AM Thread Starter
I'll give it a try... Then once I get the wheel off I am going to buy a new stud since the reason it probally spun is the threads are gawled or really rusty. Then once I have it pressed back in by way of lugnut and a stack of washers I will mig a small bead on the back for extra insurance. Thanks for the advice.
zoomy4 is offline
post #6 of (permalink) Old 08-31-2000, 08:39 AM
I had the same problem and had to air chisel it off.
From what I've found, you can only get the front studs from a Suzi dealer or maybe from Hawk Suzuki.
Napa carries the back studs.
Good Luck!
Thanks,
Shawn
post #7 of (permalink) Old 08-31-2000, 11:59 AM
zooky's Avatar
if you have a compressor and an impact gun you may be able to get it off
zooky is offline
post #8 of (permalink) Old 08-31-2000, 09:30 PM Thread Starter
I got it off! Gee, that doesn't sound right... Last night before I retired to the internet I applied liberal amounts of Kroil to the nut and left it overnight. This afternoon I fired off the compressor and hit it with my impact and wouldn't you know it came loose. Thanks for the help. Like I said I am new to Samurai's. I had this happen on an older Chevy rear drum and had no choice than to torch them off. I will drop a small bead on all of the front studs so this will not happen again. Still looking for a couple studs to stick in my tool box just in case I do ever need one. Especially if they are as scarce as you say they are. Thanks again.
Wife thinks I bought a Samurai because it's good on gas. She doesn't know is I am secretly building a Tiny Giant Killer! Now how do I hide the 33" Swampers and do a SPOA next time she goes shopping?
zoomy4 is offline
post #9 of (permalink) Old 09-02-2000, 07:48 AM Thread Starter
Damn if you wern't right about the availability of those wheel studs! I went to two differnet Pep Boy's, one Trak Auto and Auto Zone and they all have them listed in the book however when you look on the shelf, they are not there. I will try some foriegn car places next and then if all fails drive to the Suzuki dealership. Luckly I still have one around me. There use to be three of them, now just one left.
zoomy4 is offline
post #10 of (permalink) Old 09-02-2000, 10:25 AM
Have you tried Carquest? I bought some front wheel studs there.
88.5 Samurai is offline
