electric fan - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-23-2000, 04:32 PM
electric fan
has anybody swapped the mechanical fan to and electric? would it help free up some extra power? i have hearfd of other vehicles doing this but not suzukis. just curious.
brian wilson
80 cj5 "high 5"
stretched to 100" wb
351w/np435/d300/d44/d60/detroits/4.56/35ss/bdlocks
post #2 of (permalink) Old 08-23-2000, 05:01 PM
Re: electric fan
I replaced my manual fan with electric this weekend. It took me longer to figure out how i wanted to wire it than to install. I have it wired with a tempeture switch to turn it on when it warms up to a certian temp. I also used the manual switch inline so that I can turn off the fan in deep water crossings.
this is what I learned.
1. Get the largest fan you can get to fit. (More air flow the better) Measure the width and hight of the radator fins.
2. you do not have to remove the radator to install the fan just losen it up at the frame.
3. I set mine up as a pusher and mounted it in the front of the radiator. The instructions that come with the fane explain how to do this.
4. If you want to replace the stock manual fan then you will need a temperature activated switch the maker of the fan will have them .
I do not have the slight overheating (got warmer than i wanted)issue I have had since the installation of the 1.6 at idle. The motor serems to spin up easer and have a little extra at the higher RPMs.
Sorry for the book and the spelling.
LOCO
post #3 of (permalink) Old 08-23-2000, 06:19 PM
Re: electric fan
No sorrys, i like books. What kind of fan did you use, how much $, and you say its push style into your 1.6L? Since you measured the fan width and length, can you share some specs on it? Thanks a bunch, Max
Just one more of the elite Samurai![img]/wwwthreads_images/icons/wink.gif[/img]
mxnhid is offline
post #4 of (permalink) Old 08-23-2000, 07:31 PM
Re: electric fan
I ran with only an electric fan last year with no problems, used as a puller fan (pulled air through rad), This summer I reinstalled my mechanical fan and moved my elect to the front of the rad. I did not notice any power increases with out the mechanical fan.
I went to Autozone (if you have these in your area) and bought the smallest fan they had, and the temp switch, I sandwiched it between the hood latch and the splash shield, I didn't even have to mount it to the rad. Check the attached pict out
Ford guy with twin rockcrawling Samurai's [img]/wwwthreads_images/icons/wink.gif[/img]
[email protected]
post #5 of (permalink) Old 08-23-2000, 08:13 PM
Re: electric fan
I used an Imperial 12" part number 226112 thermostat switch part number 226203.
cost 112 dallars for both the fan and the switch.
hope that helps,
LOCO
post #6 of (permalink) Old 08-23-2000, 08:37 PM
Re: electric fan
i installed a 10" aux fan to cool my 4.3 eng.i am going to change it to a 14" and remove my mech. fan.as others have said,wire it so you can shut it off for deep water .a mech fan will pull 3/7 HP. alt to power elec will pull 1/2 HP. HOPE IT HELPS RANGER RICK
THANK GOD FOR VETERANS AND SUZUKIS-BOTH KEEP YOU FREE. FOUNDER;INDIANA SUZUKI EMERGENCY RESPONSE TEAM
rangerrick is offline
post #7 of (permalink) Old 08-24-2000, 11:33 AM
Re: electric fan
Hmmm 3/7ths of an HP is less than 1/2 of an HP....Hahaha
Sorry, got up too early today.
Troy
<a href="http://www.AbusiveMotorSports.com>www.AbusiveMotorSports. com<a/>
post #8 of (permalink) Old 08-24-2000, 04:24 PM
Re: electric fan
sorry troy. should read 3 to 7 hp and 1 to 2 hp.have a great weekend troy-ranger
