Steering woes - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-10-2000, 09:16 PM Thread Starter
Steering woes
I'm having some probs with my steering on my Samurai. The only mods to the steering is a 3" dropped pitman arm. I was told the problem was my steering box, so I changed it. The steering is alot better, but I still have a problem. When I cut the steering wheel hard to the left(going slow or stopped), the steering (at speed) has alot of play to the left. Also does exactly the same if I turn the wheel hard to the right while stopped or moving slow. I've searched through my factory manual for answers, but don't know what to try next. Any suggestions?
88.5 Samurai is offline
post #2 of (permalink) Old 08-11-2000, 08:40 AM
Re: Steering woes
Well, there are relatively few things left to run down:
-Drag link joint at tie rod assembly.
-Tie rod ends (2).
-Trunion bearings aka kingpin bearings-- the ones that allow your wheels to turn/swing left & right. Jack a wheel up off of the ground & see if you can move the wheel up & down any.
-Wheel bearings--if the wheel will move up & down, check to see if the knuckle assembly is moving, or just the wheel/hub itself. If knuckle moves = trunion brgs. If hub moves = wheel brngs.
-Might wanna go ahead & lift the front end off of the ground, support the frame, and then let the front end hang loose. Then see if there is excessive lateral movement = leaf spring bushings.
HTH,
TJ
