Re: Glenn............Strange Engine Noise.
I'm probley the wrong Glenn But I'll give it a go, The engine in question is a toyota 22R? Or is it a zuke stock engine? either way sounds like it is time for a compression test and check your oil pressure. The trick with
the long screwdriver (Ala Rangerrick ) is to replace a stehascope. Very usefull. If your compression is low
for whichever engine it is, squirt some oil in each cylinder (Just one or two pumps from a can) and try again.
If the compression jumps up then the rings are tired and it could be time for a rebuild/replacment.
if your oil pressure is low then it could be your bearings.. Have you changed your oil lately? what did it look like?
Hows your timing?
Good luck.
Glenn Loud
87' Zuke Spoa, 31's, 4.16 tcase, Camo,Header,2"exhuast, Cam.
Locked both ends, 8klb winch, Snorkel -Wildweasel2
NE4WI- club
