1.9td swap 4th gear vibration - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-28-2009, 06:04 PM Thread Starter
Hi guys im new here.. I just got done putting a 1.9td in my samurai and everything works great except 4th gear between 30-35 mph I get a bad vibration when accelerating. Ive tried changing trans oil to synthetic and that made it worse. The other gears are pretty quiet. Is it just time for a rebuild? Any help is appreciated thanks
grunttorque is offline
post #2 of (permalink) Old 02-28-2009, 08:25 PM
Apprentice
AUGETER's Avatar
4th gear vibration
What transmission are you using? If it is stock Samurai it sounds like your center bearing is getting loose. How is 5th gear? Have you checked your rear trans mount, transfer case mounts. Also if the alignment(Engine&trans) if off just a little will amplify any loose U-joints and/or mounts.
Batteries not included, Your mileage will vary.
AUGETER is offline
post #3 of (permalink) Old 03-01-2009, 05:04 PM Thread Starter
I am using the stock samurai trans. The only mount in question might be the rear trans mount it looks like it might be getting pushed back slightly because the center bolt isn't in the center when looking at it from the bottom.
post #4 of (permalink) Old 04-10-2009, 09:55 PM
Quote:
Hi Friend,just joined this forum.Did u do any work to your drive shafts [shorten/lenghten] because if the linen up was not done properly or the machine work that could be your problem,these suzuki samurai drive shafts are very sensitive.
straydog is offline
post #5 of (permalink) Old 04-11-2009, 11:06 AM
Apprentice
AUGETER's Avatar
Vibration?
Still have it? If you solved it let us know, if not I just developed a low speed vibration myself and I am now changing my u-joints, one was really bad! I could not detect any excessive play in my driveshaft but when I unbolted it the u-joints were so tight they would only move with a lot of effort. If you ever change a u-joint Suzuki OEM u-joints last the longest and are the best, I would not use any other.
AUGETER is offline
post #6 of (permalink) Old 04-19-2009, 03:04 PM Thread Starter
Yep I still have it.. I'm going crazy trying to figure it out. I pulled the rubber boot off the tcase shifter so I could see the middle shaft. I put the tcase in neutral and the trans in 4th and its definitely coming from that intermediate shaft. I'm just hoping the engine conversion plate isn't off throwing everything out of wack. The u joints seem solid
post #7 of (permalink) Old 05-11-2009, 08:01 PM
Apprentice
SWIMMER217's Avatar
You might try the intermediate shaft, they can go bad, especially with that much torque being applied to it. Samurai transmissions are notorious for having bad center bearings. Rebuilding one isn't all that hard either.
I heard I was getting a sweater for Christmas. Too bad, I was hoping for a moaner or a screamer.
SWIMMER217 is offline
post #8 of (permalink) Old 05-13-2009, 02:24 PM
I had a similar problem a few years back on my 87 sammy... Ended up being the pilot bearing
Gator is offline
post #9 of (permalink) Old 05-15-2009, 11:15 AM
Have you considered replacing the mounting arms with re-inforced ones (mighty kong) or some other? There is alot of force and those arms on the T/C twist easily.
Just a thot
billybob_CA
billybob is offline
