Body Lift - 2" vs 3" - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-05-2009, 09:42 PM Thread Starter
Zukinator's Avatar
I just put 31x10.50s on and have some rubbing at the back of the front fender wells. I was thinking that a body lift might be the most economical way to fix this and keep from having to cut up the fender wells any more. I've looked at the RRO 2" body lift - their site says the 3" kit is more complicated and could cause some steering knuckle problems. The 3" Calmini kit says it comes with everything but I'm not sure if it is as easy as they say - esp. when you consider what the RRO site says.
The rubbing on the trail is worst when the wheel is turned. The photo shows the clearance but this is cut in half when the wheels are turned. Flex it at all and it gets into the fender. Is 2" enough - according to the RRO site, probably - they have 4" with 2" body lift and 33s. I've got a spring over (approx. 4" - stock springs) and was considering adding the 2" body lift as the fix.
I searched and didn't really find the answers. Figured someone out there might have gone through this or has the same set up that I do.
Thoughts and suggestions appreciated. Thanks.
Zukinator is offline
post #2 of (permalink) Old 01-05-2009, 09:48 PM
Zuk Jr.'s Avatar
I wouldn't get a 3" body lift... take it from someone who had one! A 2" is the MAX you should go with. I think 2" lift would take care of that, if not...add a 1" shackle lift with it and you should be good to go!
Or like many have done... take a BFH to it and bang away!
BTW, I'd consider taking off those plastic rocker panels... that is where the Zuks start to rust like crazy!
-BRIAN
My Web-Page
Zuk Jr. is offline
post #3 of (permalink) Old 01-05-2009, 10:06 PM Thread Starter
Zukinator's Avatar
I'll start with the 2" (was also looking ahead - I think 2" is needed if I put in a 16v later - 1.6 8v is serving well for now though).
You are right about the rust - I've got some peeking out from behind the plastic at my drivers door. Will get them off asap. Did you replace yours with something else?
post #4 of (permalink) Old 01-05-2009, 10:15 PM
Zuk Jr.'s Avatar
I took them off and put some bedliner stuff on there, after I fixed some of the rust spots.
-BRIAN
My Web-Page
Zuk Jr. is offline
post #5 of (permalink) Old 01-06-2009, 07:59 PM Thread Starter
Zukinator's Avatar
Thanks. Appreciate the help.
William
post #6 of (permalink) Old 01-08-2009, 11:59 AM
Yankee Tim's Avatar
Quote:
I'd go 2" and see if that clears. Keeps a lower center of gravity.
But, that said...
Believe half of what you see, a quarter of what you hear and NOTHING YOU READ FROM OLIVE GREEN WEB PAGES!
Yankee Tim
Yankee Tim is offline
post #7 of (permalink) Old 01-20-2009, 11:38 PM
I say 0" and go with a virtual lift
A cross country trip in a samurai, is a lot like rowing to to England in a rubber raft!
supazuk is offline
post #8 of (permalink) Old 02-08-2009, 07:56 PM Thread Starter
Zukinator's Avatar
Thanks Tim - read you loud and clear.
I got the lift in yesterday. All went in o.k. - instructions said to re-use the rubber between the block and frame. Didn't say to use the use the rubber on the bottom. There wasn't much left of them anyway. If they are needed, I'll have to get some from somewhere. Only other thing was the brake lines under the hood. I might have to drill some new holes. I ran out of time.
Ran it though the ditches and still have some rubbing if flexing it. Looks as though the axle needs to come forward or I need to do some trimming. Any other thoughts or ideas are appreciated.
