Newbie from Idaho - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-14-2008, 03:31 PM
Idaho Chukar
Wink Newbie from Idaho
Tomorrow I'm picking up my first Sammi down in L.A. and driving it back home. Once I get it there's going to be some stuff I'll play with so I guess I'll be around looking for advice, etc.
The enginehas been rebuilt( long block or short I don't know), replaced water pump, oil pump, alternator, carb either rebuilt or replaced, replaced entire clutch assembly(pressure plate,disc, throw out bearing and pilot shaft bearing, transmission and transfer case(including all new bearings, bushings, and seals, new radiator, fan clutch, entire exhaust system, brakes, upholstery, and soft top. The body is free of rust, dents and scratches but the paint is a bit dull.....gee whizzzz, I can live with that for awhile.
The owner tells me that while towing it behind his RV, (I think I understood this) one of the support wheels in the rear went out and caused the Sammi rear tire take a hell of a ride. I read a little about these Sammi's being towed in N and didn't take it all in but maybe you guys know. This will not be towed by me anywhere so I didn't pay much attention to it.
I'm putting a great amount of trust in this seller but he seems to be as anal as I am and my gut feeling is it'll be fine. I don't want to make a rock crawler out of this Sammi as I have a Rokon that'll take me anywhere I have the kahoonas to go. But I will need to do a tire change to start out with and will have to look into this Web carb thing as well. From doing my homework I see the best way to get more power to start with: a K&H air filter, a MSD Ignition System, a Tri-Y Header exhaust and a 2" free flowing pipe. That being said, I just wonder what % changes will 'REALLY' take place?
This is going to be my hunting rig and run around town with. I need to figure out how to mount my high lift jack and maybe get the spare tire up on a cargo roof. I have a small little trailer I can pull to carry the Rokon and other gear so maybe I'll not need the cargo rack. Here's what I have been driving for the last 20 years or so
Big change but 10 mpg is no longer a write off as I recently retired....hence a small rig I can take the dogs hunting in.
Hope this all comes out as this is my first post here. When I get back I'll drop in again for an update. Wish me luck.
post #2 of (permalink) Old 01-14-2008, 06:35 PM
ackerdackerly's Avatar
Welcome, Idaho Newbie!
The first thing that you need to do with your samurai, is drive it stock offroad. That will give you an idea of what a wonderful truck you have without spending a dime!
I went through the "buy stuff to make it more peppy" phase and I offer this advice:
1. Unless the engine is truly in great shape, begin thinking about swapping it out for the larger 1.6 L engine. An 8-valve and a Weber is nice. An 8-valve and a "Harley carb" kit like ZOR's MySide is better (no stalling problems on steep inclines) and a 1.6 16-valve EFI is best.
2. An aftermarket header and larger exhaust system (2" is good) will help in the power department.
3. If you are wanting to regear, start with the difs. Some here would disagree and say "buy a set of transfer case gears", but I got good results without overloading the drivetrain by installing Tracker/Sidekick 4.625 front Ring and pinion sets. You can always pop for transfer case gears later if you want to.
4. There is a place on the internet that you should check out. It's called Ack's FAQ. It has a searchable database of links to just about every useful piece of information about Suzuki offroading. It's the answer to every newbie's questions. I know -- because this former newbie built and runs it.
Ack's FAQ: Suzuki Samurai, Sidekick and Geo Tracker 4X4 offroading information
Welcome to the ORC Geo Forum and welcome to the world of Suzuki 4x4 Offroading!
Ack
Ack's FAQ
nearly 837 searchable links to Suzuki/Geo modding and maintenence info - including the Tracker FSM Project!
'88 "SJ-416 Samurai"
'11 Ford Transit Connect XLT
ackerdackerly is offline
post #3 of (permalink) Old 01-14-2008, 09:41 PM
Idaho Chukar
Spot on with your advice...drive it first
I have a Harley with about the same size engine so I'm sure I'm in for a surprise with a Sammi.....1/3 the weight with the same size engine....wow. I've already 'tricked out' the Harley with the carb and exhaust w/o messing with the original power.
This time around with the Sammi I'll see what will happen stock but I'd like to know what I can expect with dropping the guidas into a Sammi as you suggest.....and thank you for your suggestions. My true 'rock crawler' is a 'Rokon' which no vehicle...4 wheel or two wheel can even begin to compete with in performance.
I don't think I'll be a rock crawler with the Sammi.....just using it to get back up into the Idaho 'STEEP' mountains where I'll drop off the Rokon and go to out back places no one can go unless they're on a horse.
Sure appreciate your advice.
post #4 of (permalink) Old 01-15-2008, 09:03 AM
Yankee Tim's Avatar
Welcome aboard, fellow Zooker.
Be sure to search this BBS for any questions you may have. This is one of the oldest all-zook BBS on the web, and has a buttload of info.
Yankee Tim
Yankee Tim is offline
post #5 of (permalink) Old 01-15-2008, 09:18 AM
Zuk Jr.'s Avatar
Welcome... lots of good info here and people!
Nice, clean looking Zuk you are getting!
-BRIAN
My Web-Page
Zuk Jr. is offline
post #6 of (permalink) Old 01-15-2008, 04:58 PM
welcome aboard. and that Rokon is a real interesting looking little vehicle there.
good luck with everything
Different Strokes for Different Folks
90 Sami - MULE trailrig
Remember: History is written by the victor.
Mule_Zuk is offline
post #7 of (permalink) Old 01-16-2008, 05:28 AM
Apprentice
Gotzook's Avatar
Welcome. Your lucky to have such a clean Samurai. I haven't seen one like that in the NE in years.
Gotzook is offline
post #8 of (permalink) Old 02-08-2008, 04:20 PM
Apprentice
Welcome...
PM sent today.
MTGunner is offline
