Info on 8v to 16v tracker - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-05-2007, 02:23 PM
Robert Shelton
I have a 94 Tracker, 8v, auto, 2wd and wanting to put 96 16v FI, 5sp, 4x4 running gear in the 94. What kind of trouble am I going to have with the wiring harness and box??? change it all out ---modify---- or what????
post #2 of (permalink) Old 06-07-2007, 01:07 PM
James_Holland's Avatar
It will probably be easiest to change out the wiring harness, the ECU and sensors are quite different. I'm not familiar with the auto boxes, I know there is what is called an Auto Lock Out function that is usually controlled by the ECU. Someone else should know if you can run the auto without this.
2000 Vitara 1.6, 2" lift, 3" body lift, winch, snorkel, safari rack, 33" MTs, rear discs, steel front axle, 5:83s
SJ413K Pick Up, 1.6 conversion.
James_Holland is offline
post #3 of (permalink) Old 06-14-2007, 06:48 PM
Contact Brad at Trail Tough... he does alot of these conversions and is very knowledgeable.
First question I have is do you have a donor vehicle? Just the engine & tranny or what?
I know that you can buy the modified harnesses but they can be expensive... otheer thing is the OBDI vs OBDII systems. The OBDII is the standard on the 96 and newer whereas the OBDI is 95 and earlier....
differences are the OBDII have twice as many sensors and if you're in Kaliforny emissions controls are stringent and OBDI is far easier to smog... and the OBDII engines can be changed to accept the OBDI ECU and harness... that's what I did with my 96... made it into a 95
L8R
billybob_CA
billybob is offline
