Need Help! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-30-2007, 06:51 AM
Larry Hatcher
Need Help!
We put the 95 Geo motor into the 90 body! We did have to use the old dist. because of the vac. advance! 95-had elec. advance! Info from computer says the 90 dist. turns clock-wise....an the 95 turns counter! Fireing order is back-wards! Will this dist. not work? Its firing at the plugs but not in time!..Number 1 plug is set on the 1st cyl..........could I just b 180-degrees off? Will I hav to make the newer dist. work? any-help would b great!!
Thanks Guys!
post #2 of (permalink) Old 04-30-2007, 07:18 AM
James_Holland's Avatar
Quote:
Thanks Guys!
Is the 95 motor a 16V?
2000 Vitara 1.6, 2" lift, 3" body lift, winch, snorkel, safari rack, 33" MTs, rear discs, steel front axle, 5:83s
SJ413K Pick Up, 1.6 conversion.
James_Holland is offline
post #3 of (permalink) Old 04-30-2007, 05:34 PM
zooky's Avatar
Exclamation
Thanks Guys!
too many explanation points!!!!!
Bacon is quite wonderful
Bacon is quite good
I would eat it every day
If I freakin could
zooky is offline
post #4 of (permalink) Old 05-09-2007, 06:45 AM
Larry Hatcher
Electric Fuel pump-Geo
1990-Geo..........fuel pump is gone.........how do you take the old one out of tank? Does it twist? if so which direction?It has several phillip-screws on top.....? Does anyone out there have a good used one or have found a less expensive one that works? My timing was 180 degrees off! It solved my timimg issue.......thanks for the help Guys!!!
L. Hatch
