What kind of PSI do u get with the zuk onboard air - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-19-2007, 06:47 PM Thread Starter
dparker's Avatar
i still have a zuk air compressor and im wanting to do a onboard air with tank so im wonder well i be able to run impacts of these? or do i need to hunt up a York compressor ????? so for those of you that have done this what kind psi can you build up
dparker is offline
post #2 of (permalink) Old 01-19-2007, 10:30 PM
Re: What kind of PSI do u get with the zuk onboard
When i did mine several years ago, I had about a 2gal tank. good for airing up tires. The pressure switch was set to 100psi. The a/c can build the pressure but not the cfm. if you dont have a big enough tank, you can forget about running a impact. dont forget about an inline oiler on the inlet.
suzuki1750 is offline
post #3 of (permalink) Old 01-19-2007, 11:54 PM Thread Starter
dparker's Avatar
sounds like im going to a york
dparker is offline
post #4 of (permalink) Old 01-22-2007, 09:26 AM
Yankee Tim's Avatar
Re: What kind of PSI do u get with the zuk onboard air
My OBA trips the switch at 120#. I use a large tank, and can handle powertools quite easily. Never had a problem is I only air MY tires. [img]/ubbthreads/images/graemlins/cussing.gif[/img]
Yankee Tim is offline
post #5 of (permalink) Old 01-22-2007, 04:05 PM
zooky's Avatar
my pump worked great but it would run SOOOOOO hot. I never ran air tools so I swapped from a 120psi to a 50 psi switch and the pump was much happier. I never aired up to 120psi so there was no need to put my pump through that
[img]/ubbthreads/images/graemlins/headspin.gif[/img]
zooky is offline
post #6 of (permalink) Old 01-22-2007, 06:54 PM
I just bought a Max Air 4.0 , the whole kit w/3gal. tank was $400. Max pressure of 150psi and constant duty , fully rebuildable. There is an ExtremeAir Severe duty model that will go to 6cfm but it's around $550 . Just don't have the room on this engine for all that extra crap, so electric was the best way to go.
Sarge
Sarge is offline
post #7 of (permalink) Old 01-22-2007, 07:48 PM
zooky's Avatar
if your gonna go 12v this is a good deal
zooky is offline
post #8 of (permalink) Old 01-23-2007, 04:06 PM
Yankee Tim's Avatar
[ QUOTE ]
Ever thing of using K-Y Jelly when you pump? [img]/ubbthreads/images/graemlins/thumbsup.gif[/img]
Mine would boil water on it, but run is still did. I've got 3 more as back-ups, figuring I would change them like condoms, but alas, the original still works great. Just kept it well oiled. Still got the back-ups.
post #9 of (permalink) Old 01-23-2007, 06:15 PM Thread Starter
dparker's Avatar
so tell me how to build this oiler system? i plan on running about a 2.5gl tanks
dparker is offline
post #10 of (permalink) Old 01-23-2007, 09:32 PM
I used one of the inline oil dripper things. It looks kindof like a mini drier, but u put oil in it and there is a little glass bulb on top. There is a adjuster on top to control the oil drip speed. Mount it as close to the compressor as possible. Here is a pic of it and a vendor for you.
http://www.grainger.com/Grainger/wwg...mId=1613590044
