Help : Truck Not Starting Part II - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-24-2005, 03:31 PM Thread Starter
Original thread here
OK... So the new timingbelt is on but I am still having small problems. I did the entire procedure listed in the orignal thread but somehow must have mess it up. I just can't get the truck to go. I get a couple of spurts here and there but it won't catch. What I am doing to solve this is the following.
1) turn crankbolt until piston one (closest to grill) reaches TDC (approx)
2) remove the dist. cap and adjustment screw
3) lift the dist so that I can turn the rotor manually to spark plug one
4) turn the engine
5) if doesn't start rotate the rotor 180 degrees and try again
Does the above look good to you guys. The only thing I am not sure of if the rotating 180 degrees. I seem to remember reading it in another posting. The reason I am assuming you need to do the 180 rotation is because you don't know on TDC of piston #1 if the cam and crankshaft markings are pointing at each other.
Thanks
Lil_Mudder is offline
post #2 of (permalink) Old 01-24-2005, 04:34 PM
Re: Help : Truck Not Starting Part II
When you got under the timing belt cover and discovered it was broken did you align the cam/crank sprockets per the procedure outlined in your manual BEFORE you slid the new belt on?
Sounds they are way out of whack to me....
Cosmo is offline
post #3 of (permalink) Old 01-24-2005, 05:45 PM
If the cam and crank marks are both in the center pointing up and your distributer is 180 deg off the number one wire on the dis cap. Then its just TDC on the exaust stroke. If you have the belt on with the tentioner rotate the crank 1 full rotation, now its on the compustion stroke and every thing should be good on that part.
mug_Shot is offline
post #4 of (permalink) Old 01-24-2005, 07:44 PM Thread Starter
As per the original instructions everything was lined up properly meaning that the cam gear mark was pointing at 6 and the crankshaft mark was pointing at 12.
post #5 of (permalink) Old 01-24-2005, 08:27 PM
TomKat's Avatar
lemme guess, you have a haynes manual? Burn it for heat, thats all it's worth. Both gears marks should be at 12 o'clock, pointing directly at the locator marks on the oil pump housing and cam timing gear back plate, go recheck, something must be off. Did it run fine before the timing belt change? [img]images/graemlins/confused.gif[/img]
TomKat is offline
post #6 of (permalink) Old 01-24-2005, 09:49 PM Thread Starter
Yes the truck ran fine before the belt broke. So your saying that the crank and cam bolts should both be pointing at 12? Is so that isn't what I got in the original thread. I'll check my chilton manual and see what it says.
Thanks
post #7 of (permalink) Old 01-25-2005, 01:56 AM
Index cylinder #1= cam at 6 o'clock , crank at 12 o'clock.
Index cylinder #4= cam at 12 o'clock, crank at 12 o'clock.
Pro tip: use a straightedge of some sort , ruler , angle iron or whatever you want . Centerline between the cam sprocket bolt and the crank sprocket bolt should line up both marks , don't just eyeball it as the engine sits at an angle . You'd be surprised how many folks have screwed this up trying to eyeball it ...
Sarge
Sarge is offline
post #8 of (permalink) Old 01-25-2005, 06:27 AM
bradzuki's Avatar
When you put the belt on the crank must've been on exhaust stroke instead of compression. Crank turns twice for every single turn of the cam.
Brad.
bradzuki is offline
post #9 of (permalink) Old 01-25-2005, 09:34 AM Thread Starter
Man this is getting a little frustrating [img]images/graemlins/cussing.gif[/img].... Ok... So on cylinder #1 at TDC how do I know if its the compressions stroke or the exhaust stroke? From what I read above having the cam mark at 6 and the crank mark at 12 doesn't necessarily mean that I am on the compression stroke.
I hope there is a simple answer to this. I just want to drive my Zuke again.... [img]images/graemlins/wall.gif[/img]
This explains why in some posts in the past there was a mention of 180 out of phase. The positive about this posting is that I'm learning alot.
I need some advice on a procedure to move forward with as minimal disassembly as possible. Having everything put back together what would you guys suggest I do to get this running as easily as possible. If I could just get it running even badly and then adjust the timing I would be set.
post #10 of (permalink) Old 01-25-2005, 09:43 AM
On TDC COMPRESSION stroke....#1 piston will be at the TOP of the cylinder....
TDC on EXHAUST stroke the piston will be at the bottom of the cylinder.
Either way crank pully will be aligned with timing mark..
If you get TDC on compression stroke and rotor DOES NOT point to #1 on the cap.....that is your problem.
Don't you have a manual???? Sure would save you alot of time posting/waiting for answers....best $12-$15 you will spend.
Cosmo is offline
