Coil polarity - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-29-2004, 11:47 AM Thread Starter
Coil polarity
OK, I'm confused.
Setting the timing on my 87 tintop. Just installed a new Accel super coil day before.
Try to hook up my dwell-tach meter to measure idle speed, black clip to ground, red clip to positive + terminal on ignition coil according to instructions... Doesn't work. Red clip to negative - terminal on coil, it works.
Think, hmm, polarity is reversed. Examine more closely; have a brown wire going to the negative terminal, black / white stripe wire going to positive.
Get out multi-meter. Detatch wires from coil and measure with ignition on (but obviously engine not running). Black/white stripe has 12.7 + volts to ground. Brown wire has fluctuating + .0 to + 3.3 v to ground.
Turn ignition off, check to see if either wire is grounded, Nope, neither wire goes directly to ground.
FSM and Haynes of no help in determining which wire goes to which terminal. Nor does a search of all the Suzuki forums.
How do you determine which wire goes to which terminal? Is it possible that the factory polarity markings on the coil are reversed?
Or does it even matter?
Silviron is offline
post #2 of (permalink) Old 11-29-2004, 12:58 PM
James_Holland's Avatar
Re: Coil polarity
The FSM for an old Vit (Track/Kick) shows the coil -ve to be brown/white and the black/white to be +ve. I wouldn't imagine that they would change their colour scheme for wiring very much between models. Black or black/white seems to be fairly standard for +ve amongst Japanese manufacturers. As to why it doesn't work I'd imagine that its to do with the very short dwell time you get with an electronic system. The coil must be connected the correct way round to get a spark.
James_Holland is offline
post #3 of (permalink) Old 11-30-2004, 07:05 PM Thread Starter
Re: Coil polarity
Thanks for the input-
Still doesn't make sense that the tach meter worked properly and accurately last time I tuned the engine, and now it works OK with the (apparently) wrong terminal on the new coil.
Oh well, it runs OK so I guess it doesn't matter too much. Just thought it was kind of weird.
Silviron is offline
