Stiff steering - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-08-2004, 05:18 PM Thread Starter
Stiff steering
It's been a small problem since I bought this, but it's getting worse.
The steering is very stiff, and the column groans while turning. Everything is stock, tire size is 215/75 15's (I believe, I'll check when I leave work).
Just curious what and where I need to lubricate things on the steering system to free it up some. I had to parallel park this morning and had a tough time with the thing, even though sammy's aren't that terrible to parellel park. [img]images/graemlins/smile.gif[/img]
Thanks for any help.
87tintopzuk is offline
post #2 of (permalink) Old 11-08-2004, 06:43 PM
87zuke's Avatar
Re: Stiff steering
The groan is probably the bearing in the firewall where the steering comes through. Just get some grease and squirt it up in there. I don't think it would stiff steering though. Maybe but try it. You may need some lube in the box too. Also see if anything looks bent. Jim
87zuke is offline
post #3 of (permalink) Old 11-08-2004, 07:01 PM
Re: Stiff steering
This may sound like a stupid question, but...
You do realize that there is no power steering in these things, right?
JerseyZuks is offline
post #4 of (permalink) Old 11-08-2004, 07:19 PM
Re: Stiff steering
This is stupid simple.....make sure you have enough air in your tires. If you're mostly onroad no reason not to run 20 psi or more.
AZtoyguy !! is offline
post #5 of (permalink) Old 11-08-2004, 10:29 PM Thread Starter
Re: Stiff steering
Yea, I know these don't have power steering. The 87 soft top I used to have had much easier steering than this one does. The tires stay at their rated 35 PSI, but their due for a change here soon with some new 235/75's.
I'll take a look at the bearings at the firewall, and where do I add lube to the steering box? I looked at it the other day and couldn't see anyplace for fluid or a grease zerk, but it's covered in dirt and grime, so maybe that's why.
post #6 of (permalink) Old 11-08-2004, 11:46 PM
daxe's Avatar
Re: Stiff steering
SQuirt the place where the steering column passes through the firewall. grease up the litte U joint, too.
There is a cap on the top of the steering box. it may be mostly obscured by the radiator support. If the box is caked real good with crud then you probably have a leak.
When I got my sami about 3.5 years ago it did the same thing you mention. After greasing up the steering shaft I discovered the steering box was bone dry... all the gear lube ran out long before I got it. I poured in some more and kept it topped off and the groaning went away until I replaced the box.
There's also an adjuster screw on the box for steering slop.
~daxe
daxe is offline
post #7 of (permalink) Old 11-09-2004, 01:33 AM
upsman
Re: Stiff steering
my 87 tin top did the same thing it was a bent steering stabl
post #8 of (permalink) Old 11-09-2004, 11:03 AM Thread Starter
Re: Stiff steering
Thanks Daxe, I'll pull it in to the garage tonight and take a look at it.
I've got some left over gear oil from when I changed the transmission oil, is that alright to use? If not, what's recommended?
