Tracker tranny progress pics - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-05-2004, 05:58 PM Thread Starter
frsuki's Avatar
So far so good !! Just finished shortening the intermediate shaft at work today. Any comments ? 1st pic
frsuki is offline
post #2 of (permalink) Old 11-05-2004, 06:00 PM Thread Starter
frsuki's Avatar
Re: Tracker tranny progress pics
2nd
frsuki is offline
post #3 of (permalink) Old 11-05-2004, 06:00 PM Thread Starter
frsuki's Avatar
3rd If anyone can see a problem with anything please let me know. I'm very green with this type of work. And also what do I do about the speedo outlet ? Do I have to block it off ?
frsuki is offline
post #4 of (permalink) Old 11-05-2004, 08:40 PM
frsuki:
What type of set up are you going for??
Anarchy Joe [img]images/graemlins/40BEER.gif[/img]
anarchy_joe is offline
post #5 of (permalink) Old 11-06-2004, 04:55 AM Thread Starter
frsuki's Avatar
What do you mean by "set up" ? Just a basic dd zuk and occasional off roading.
frsuki is offline
post #6 of (permalink) Old 11-06-2004, 12:35 PM
Looks Good !!
I'v run a tracker tranny for years.
I'm curious on the transmission mounting point. On mine I was able to get both bolt holes from the tranny mount over the sammi's trans cross member..ie.I was able to use both bolts on the trans mount. Was yours cut short?
Did you widen the trans tunnel at all?
At first I did very little widening. I found that the "Frankenstein" bolts just below the shifter opening would hit the sides of the trans tunnel while driving and THUMP it real good if I got on the gas. It was just too annoying.
So, I did the cut-n-widen the trans tunnel about 3" on the drivers side and also did the "flip the body mounts" for a quick 3/4" body lift. This seemed to work and the only annoying noise left when driving was the 16v exhaust manifold lightly hitting the frame.
The hot ticket came when I decided to paint my zuke and took the body off the frame. Because of the manifold hitting the frame, I went with Petroworks engine mounts which lower the engine 3/4". I figured I'd better lower the trans as well (the PW kit comes with a sammi tranny lowering mount....must be there for a reason).
To lower the tracker tranny, I knotched the sammi's tranny crossmember where the tracker transmission mount falls on it. Then some 4 inch "C" channel was welded into the knotch. This effectively lowered the trans about 1 1/4" ( I felt the trans was already a little tail high on the sammi crossmember). Now there is all kinds of room under there. Hmmm I'm sure and auto would fit easily now.
I didn't mean for this to sound like a book about my zuke. Its a review of lessons learned.
Oh yea! the speedo outlet is a sealed unit. You can leave it alone. Mine's been packet with mud for years. [img]images/graemlins/grin.gif[/img]
whazoo is offline
post #7 of (permalink) Old 11-06-2004, 03:43 PM Thread Starter
frsuki's Avatar
Took it for a test ride today and it works great. only 1 small problem, although the spline is the same on the slip yolks the samurai yolk is smaller and it leaks gear lube from the tranny output (or at least I think so ). Maybe it's just a bad seal. Have to get a 2wd tracker slip yolk .
frsuki is offline
