White smoke everywhere!! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-01-2004, 09:12 PM Thread Starter
Started up the zook today for the first time since probably last Thursday or so... drove around the neighborhood and then came home for dinner. An hour later, I started it up and drove to the bank. I killed it and spent about 5 minutes at the ATM, and when I got back in, it blew white smoke EVERYWHERE for about 20 seconds, and then it went away. Went to the store, came back out, and it did it again... Got home, let it rest for 5 minutes and then went and tested it. White smoke again....
Any ideas about this? I'm thinking that there is water getting into the exhaust somehow... when it sits (like over the weekend) the water dries... when it only sits for a few minutes, it accumlates, and then burns off when it runs. Is this anywhere close to correct?
Also, where would the water be leaking in? This is the fist time in the last 5 years that I've owned the zook that it's done something like this...
Any ideas?
Let me know.
Thanks,
- Steve
TexasA&MOffRoad is offline
post #2 of (permalink) Old 11-01-2004, 10:41 PM
Re: White smoke everywhere!!
Head gasket
tazuki88 is offline
post #3 of (permalink) Old 11-01-2004, 10:42 PM
Are you loosing antifreeze or water from the radiator?
If so, could be the head gasket or a cracked head.---More rairly and not likely, a cracked cylinder wall at the water jacket.
AkDale is offline
post #4 of (permalink) Old 11-01-2004, 10:50 PM Thread Starter
Wouldn't that create the smoke all of the time?
post #5 of (permalink) Old 11-02-2004, 12:35 AM
Not necessarily--
I had a cracked head that only leaked when the engine had been running and I shut it down. It would hydrolock it leaked so bad. That same rig would drive over 100 iles before it ran out of water.
AkDale is offline
post #6 of (permalink) Old 11-02-2004, 07:08 AM
My guess is the head gasket. Mine did about the same after I blew the head gasket. While running the water burns off in the combustion chamber. A little water vapor mixed with the air-fuel will actually clean the combustion chamber and valves. Remember the old water injection systems. If the water has time to acculmate at long idles or at shut off it will blow white smoke on acceleration or start up.
Either that or you just elected a new Pope.
ZippytheZuke is offline
post #7 of (permalink) Old 11-02-2004, 08:43 AM Thread Starter
A new pope would be cheaper....
So what all has to be done to replace the head gasket? Also, what harm is there in driving it until it gets fixed, aside from running out of coolant? I have always wanted to do some upgrades in the head, but I don't have the cash right now, and I don't want to have to do this major work and only replace the gasket, you know?
post #8 of (permalink) Old 11-02-2004, 10:13 AM
87zuke's Avatar
i had a problem where every so often usually at a stop light the Zuke would smoke white like crazy. Turned out to be a loose bolt on the intake manifold. It was one near the center of the intake. Jim
87zuke is offline
post #9 of (permalink) Old 11-02-2004, 12:23 PM
TomKat's Avatar
Does it smell sweet? Or like oil? don't discount the all too common valve seals burning oil on startup. My sammy does the same thing, but I know its oil past the valve seals. Do a block check to see if any hydrocarbons are in your coolant.
TomKat is offline
