Rear Clank - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-01-2004, 11:04 AM Thread Starter
87zuke's Avatar
Rear Clank
I had my #2 rig out yesterday for a test drive around the block. It has a welded rear, Cjs, M/Ls and no shocks right now. I am getting a clanking sound from the rear that almost sounds like a bind. I was getting it when backing up then going forward. The welded rear? Also I think I put the drive shaft back in wrong in terms of phase. How is it supposed to be orientated? Thanks. Jim
87zuke is offline
post #2 of (permalink) Old 11-01-2004, 11:30 AM
Re: Rear Clank
chances are the clank is the 4 bolts that hold the brake drum to the axle. I believe daxe was the one who chanfered the brake drum hole to take a lug nut. since the bolts only provide clamping force. under heavy load they will alow the clearance of the bolt holes to move from one side to the other.
the jack shaft( drive line between the tranny and t case ) unless you took the driveline itself apart. it doesnt matter the alignment. the driveline between the t case and axles have a dimple. on the male end it is on the face. on the femail side I think it is on the side. just line them up and slide together.
szki272 is offline
post #3 of (permalink) Old 11-01-2004, 11:48 AM
Re: Rear Clank
Yes it could be the d-shaft. The joints are supposed to be inline. The joints on the flanges are supposed to line up with each other. I did that and it makes really funny sounds.
I haven't forgot about your merc arm...
Ciao
Oz
ozzie is offline
post #4 of (permalink) Old 11-01-2004, 11:53 AM Thread Starter
87zuke's Avatar
Re: Rear Clank
Thanks guys I am pretty sure it is wrong. I will have to check that.
Like I said Ozzie no hurry at all. Whenever yo uget to it. As long as you drive off with out me again [img]images/graemlins/shocked.gif[/img] Jim
87zuke is offline
post #5 of (permalink) Old 11-01-2004, 01:17 PM
Re: Rear Clank
In addition to the above mentioned items, it
Could be bad u-joint.
Could be bad pinion bearing.
Could be Yolk on pinion loose.
Could be back lash between pinion and ring gear.
AkDale is offline
post #6 of (permalink) Old 11-01-2004, 05:36 PM
zooky's Avatar
Re: Rear Clank
whos the HACK that welded it?
zooky is offline
post #7 of (permalink) Old 11-01-2004, 06:14 PM
Re: Rear Clank
Easy there -----
You are insulting a lot of us.
Some of us weld them properly and have no problems.
AkDale is offline
post #8 of (permalink) Old 11-01-2004, 07:41 PM
daxe's Avatar
Re: Rear Clank
Not I! A good idea, though. Wish I could take credit for it.
~daxe
daxe is offline
post #9 of (permalink) Old 11-01-2004, 08:16 PM Thread Starter
87zuke's Avatar
Re: Rear Clank
Easy there -----
HE IS the hack.[img]images/graemlins/grin.gif[/img] That is why he said it. Jim
87zuke is offline
post #10 of (permalink) Old 11-01-2004, 08:20 PM
zooky's Avatar
Re: Rear Clank
uh...yea...thats why I said that [img]images/graemlins/censor.gif[/img]
If its junk I have one
zooky is offline
