Help with SPOA - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-25-2004, 03:39 PM
tehans
Help with SPOA
I recently purchased a 88 suzuki with a homemade spring over axle lift. The only problem is when they moved the plates to the top the shock mounts are too high. I have solved the problem in the front by fabricating taller shock towers, but this is not possible on the rear.
What should I do on the rear? Make shock mounts that weld to the bottom of the axle housing ???
post #2 of (permalink) Old 10-25-2004, 04:18 PM
87zuke's Avatar
Re: Help with SPOA
Check out some of the vendors like Trailtough or Rockyroad . They have some stuff to help you out. Jim
87zuke is offline
post #3 of (permalink) Old 10-25-2004, 08:28 PM
daxe's Avatar
Re: Help with SPOA
check out sky mfg or roadless gear. they have an upper rear shock bracket that allwos you to tilt them inwards a bit (in three different positions) to allow for longer shocks.
~daxe
daxe is offline
post #4 of (permalink) Old 10-25-2004, 09:35 PM
Re: Help with SPOA
(hint, hint - fill out your profile...)
JerseyZuks is offline
post #5 of (permalink) Old 10-26-2004, 12:13 PM
tehans
Re: Help with SPOA
If I move the top of them inward, they will hit my 2" exhaust.
post #6 of (permalink) Old 10-26-2004, 07:46 PM
daxe's Avatar
Re: Help with SPOA
I have a 2" exhaust also and one of the three positions would cause them to hit, but the other two dont.
You could always move your exhaust...
~daxe
daxe is offline
post #7 of (permalink) Old 10-27-2004, 02:48 PM
cozmod1
Re: Help with SPOA
I got another set of lower spring plates with the the shock mounts and used them on the bottom and the original plates on top of the springs. I use 1/2" dia grage 8 bolts instead of the U-Bolts. This way I don't have to relocate the shock mounts.
I had one of the top shock mount reloacators, but the truck drove worse.
