Need some help guys. - Page 2 - Off-Road Forums & Discussion Groups
post #11 of (permalink) Old 11-04-2004, 10:07 PM Thread Starter
Re: Need some help guys. (pics)
I checked the timing belt and it is ok.Checked compression and have 175 on 1,2,3 and 160 on 4.
I've read of a block off plate for the EGR but can't seem to find where it is.
I only have 2 vacuum lines hooked up to the pony carb and the rest are blocked off exept for the one that goes to the tube with my k/n cone filter.
Pic number 1 is the tube that comes out under the float glass window and goes to the distributor.
Pic number 2 goes to the vacuum advance (i think).
Duleau is offline
post #12 of (permalink) Old 11-04-2004, 10:09 PM Thread Starter
Pic number 2
Duleau is offline
post #13 of (permalink) Old 11-04-2004, 11:43 PM
notjeep
did you double check the float level? I don't know this carb, but usually you should be able to see the fuel level. the float bowl should not be full. the bubbles are no big deal, it's just from the fuel flowing in. Also, bad throttle shaft bushings will not cause it to run rich. this will cause a vacuum leak and cause it to run lean.
post #14 of (permalink) Old 11-05-2004, 12:30 AM
If it was me, I would be looking into the carb. There is something wrong there that is making it dump too much fuel into the motor. You might make sure the needle valve is still properly attached to the float with the little wire clip or whatever it has. Make sure the float pivot rod is in the right spot. Also, are you absolutely sure the little check ball is back in the right spot? Was there a little tension spring that was with it? Is the carb center gasket still in good shape and installed correctly? The fuel level should be at or near the dot in the window on the bowl. I am running a pony on my stocker and it has worked great for a long time, so it has been a long time since I have been inside there. This is all I can think of right now. Good luck.
Kerry
KHalls1 is offline
