Welding Sheetmetal - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-11-2004, 08:45 AM Thread Starter
87zuke's Avatar
Welding Sheetmetal
Is it possible to weld sheetmetal(body work) with flux core? What size wire would be used? If not what gas/wire would be needed. Thanks. Jim
87zuke is offline
post #2 of (permalink) Old 06-11-2004, 11:52 AM
freebird01's Avatar
Re: Welding Sheetmetal
yes you can but it is super tough and far from pretty!!!
flux core heats the metal up too quick and warps super easy...not to mention you get bb's all over everything...
freebird01 is offline
post #3 of (permalink) Old 06-11-2004, 02:05 PM
i wire feed weld 50+ hours a week and i still have trouble trying to weld on thin pos suzuki sheet metal at home....then again the thinest steel i weld on at work is 1/4". the only welder i have at home is a lincoln pro 100 that only uses flux core .035 wire and it is challenging.
what i have found to work ok when trying to weld thin suzuki body panels using the common butt joint i flange the two ends that need to be butted together and then weld the flange on the back side. the front gap can be filled with body filler or even brazed i guess. by using the flange method it gets rid of most of the distortion.
if you can use sheilding gas and the joint is vertical, you can run a quick pass traveling down as this method gets very very little penetration. i have not had good luck running vertical down beads with flux core wire because i get quite a bit of slag inclusions.
i have used short-circuiting method of wirefeed using cheap 100% co2 sheilding gas and it works good on thin gage steel as there is less "digging" than using a argon/co2 mix.
a gentleman whose user name is "zukzilla" has mastered welding on suzuki sheet metal and should have some good tips.
blue_zuk is offline
post #4 of (permalink) Old 06-11-2004, 04:25 PM
I have done it with 0.23 wire and CO2/Aargon mix. The flanging mentioed above would produce the baest results if you can do it. I have always butt welded mine with a piece of sheetmetal straddling the joint tacked in from behind. It works OK for fender wells, small areas, or splices in the out-of-the-way areas, but I wouldn't think about doing any large areas in an area that you would want to look nice. I am not that good.
Tusker is offline
post #5 of (permalink) Old 06-11-2004, 05:27 PM
run the smaller size wire and use a copper backing plate behind
the weld. just spot weld and you will do okay. (If you try to run a bead you will not have much luck. I have a co2 bottle and regulator you can use if you want too. (about 15.00 to fill it)
or just come up and we can do it on my machine. too bad we arn't closer.
wildweasel is offline
post #6 of (permalink) Old 06-11-2004, 06:30 PM
thanks for mentioning the backing strip, i forgot all about it.
blue_zuk is offline
post #7 of (permalink) Old 06-11-2004, 10:18 PM Thread Starter
87zuke's Avatar
The reason I was asking is I am working on the 1/2 doors and was toying with the idea of welding the cap on. I thought of pop riveting the cap on but REALLY need welding time/practice. Thanks all. Jim
87zuke is offline
post #8 of (permalink) Old 06-12-2004, 01:58 PM
make sure to clean them up to bare metal and then just weld a spot every Inch or so, then grind them down some (Make sure not to go through the weld) then finish with some bondoglas.
(this is the filler with fiberglass chopped up in it, sand that down and then a little regular to smooth it out.
post #9 of (permalink) Old 06-13-2004, 12:32 AM
I use a piece of brushed stainless steel for the cap and screw it on. Works nice and wears well. Here is a pic.
Tusker is offline
post #10 of (permalink) Old 06-13-2004, 08:56 AM
I have found that my flux core 100hd works great as a plasma cutter on my zuk [img]images/graemlins/grin.gif[/img]
sammi_davis is offline
