is my clutch sensor causing starting problems - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-20-2004, 12:35 PM
lightningd
I have an 87 Sammy that has been difficult to get to start. When I push the clutch in to start, sometimes I just get a single "click",,,, the radio, clock and lights all work, battery is new.
I'm wondering if there is a clutch sensor that could be going bad. I know the clutch is getting kind of weak. But because it was bought as a first school car for my son, I really don't want to spend alot on it. (It looks good, already replaced the timing belt and cover. But doesn't have alot of power.)
Any suggestions on what I can do to eliminate the problem or what else could be causing this?
Thanks,
Doe
post #2 of (permalink) Old 05-20-2004, 12:55 PM
bradzuki's Avatar
Re: is my clutch sensor causing starting problems
Do a search for "clicky starter fix". It's a common zuk problem & very easy fix. I believe everyone on this board makes a kit to fix this. You should have no problem picking one up----usually around $10-$15. Can't look through a page of E-bay without seeing like 30 of 'em.
You can undo the wires on the clutch pedal & hook them together to check it. Be careful though, it'll start without the clutch being pushed in. Just make sure it's in neutral.
Brad.
bradzuki is offline
post #3 of (permalink) Old 05-23-2004, 01:02 PM
lightningd
I think I ruled out the sensor. Hooked the wires together, and still wouldn't start. Guess I gotta break down and buy a starter.
[img]images/graemlins/cussing.gif[/img]
Was worth a try though!
Thanks,
Doe
post #4 of (permalink) Old 05-23-2004, 03:03 PM
maybe you just need a starter solenoid. [img]images/graemlins/confused.gif[/img]
Samurai202 is offline
post #5 of (permalink) Old 05-23-2004, 09:00 PM
No idea why, two weeks ago my GF's Tracker did the same thing. Everything checked out ... strong solenoid click, good battery, no start. Banged on the starter, nothing. I double checked all the cables running to the starter and solenoid and it fired right up; worth a try anyway. I still have no idea what happened, but it's been fine since.
panewstoo is offline
post #6 of (permalink) Old 05-30-2004, 11:15 PM
lightningd
Update....
Pulled the starter, went to the local (18 miles) Napa, had it tested,,, and I quote, "works better than good." Came home, put it back on, cleaned battery terminals, (again), wiped off oil (from where the kid forgot to put the oil cap back on), went ahead and changed oil and plugs because the hood was up and had the stuff anyway, (meanwhile finding the old oil cap that rode somehow on the backside of the motor for the last two weeks so now we have an extra!!) went back under the dash, re-connected a jumper to bypass the clutch switch, ...... and NOTHING!!!...But wait,,,, got mad, wiggled some wires under the dash, tried again....VAROOOOM!!!
So it's up and running again,,, I think it was just mad at me for something.
Doe
