Help!, I think i need wheel bearings opinions? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-20-2004, 09:37 PM
scottie
I this should mean that i need to do rear wheel bearings, correct, Horrible noise Hot hub, lakeing Oil, i don't think my drum froze and it got the bearing warm and all the grease ran out, So i would assume that its the rear Bearings which i guess are a PITA
post #2 of (permalink) Old 04-21-2004, 08:16 AM
Re: Help!, I think i need wheel bearings opinions?
Yes, bearings and you should replace the seals as well. It is not that bad a job. Only pressing the new bearings on may be a challenge, but I know some people on the board did it with a pipe.
CorvetteChris is offline
post #3 of (permalink) Old 04-21-2004, 09:05 PM
It seems like I remember people freezeing the shaft over night or something and the contracting made the wheel bearings fall right off.... [img]images/graemlins/40BEER.gif[/img]
Samurai202 is offline
post #4 of (permalink) Old 04-21-2004, 10:31 PM
It is really easy job.
just make sure when you are taking off the old bearings you don't nick the shaft...very important.
I used a dremel to cut the bearings off, when I got close to the shaft, I used a wide screw driver (one I did not care about) and gave it a small whack with the hammer, and pop the bearing finished coming off.
as for the press, I just took them down to NAPA auto parts, some of them have a little shop in the back, they pressed them on for a few bucks, nice and easy.
hope this helps.
rich_d is offline
post #5 of (permalink) Old 04-21-2004, 11:07 PM
scottie
Time to order the parts tomorrow, Ah the wonders of Michigan, "If ain't fir an AMerican Car we don't stock it." [img]images/graemlins/lame.jpg[/img]
post #6 of (permalink) Old 04-22-2004, 09:43 PM
scottie
I noticed that Trail Tough sells a Bearing kit, But their kit comes with Bearings, Shim, retainer and Seal, well i just picked up my bearings and seal tonight at the parts store, Do i need this shim and retainer, or is the Retainer part of the Bearing. I bought the BCA (federal Mogul) bearings 511002, Because the Instructions that i have read have said to grind off the Retainer???
[img]images/graemlins/goodpost.gif[/img]
post #7 of (permalink) Old 04-22-2004, 10:06 PM
I believe the retainer is a metal ring that goes next to the bearing, but it has been a while. You'll need that.
post #8 of (permalink) Old 04-23-2004, 07:09 PM
Yes you will need the retainer, and I am not sure where you can get it...
when I did my bearings in the back I bought kit from TT.
I don't remember, but I think I reused the shims, but not sure..
rich_d is offline
post #9 of (permalink) Old 04-23-2004, 10:45 PM
That BCA bearing number should have the retainer built into it . If you look, one side of the inner collar sticks out farther , that side faces to the wheel side or outside . That offset replaces the older style bearing with a seperate spacer ring .
Sarge
Sarge is offline
post #10 of (permalink) Old 04-24-2004, 11:14 PM
scottie
Isn't it pretty, I pulled the Shaft today, I got a used Axle so i am just going to Swap the axle shafts then i can drive it, then fix the bearing, and keep repeating the process [img]images/graemlins/40BEER.gif[/img]
And i found my Henry Ford Slide Hammer [img]images/graemlins/AR15firing.gif[/img]
that my grandpa gave me a few years ago forgot all about until recently [img]images/graemlins/grin.gif[/img]
