Oil Pump Plugs - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-15-2004, 10:23 AM Thread Starter
Oil Pump Plugs
Does anybody know what the removeable plugs are for on the sides of the Sammy oil pump? Is it an additional place to check oil pressure? The reason I ask is that one of my recently acquired Sammy's had the oil light on at low RPM's. I obtained an oil presuure gauge and proper fitting and checked the oil pressure at the oil pressure switch location in the block. Had <5 lbs at idle and 28 lbs at 3000 rpm (Not close to spec). Wondering if it is a bad oil pump or the head gasket is in backwards. It is a supposedly "crate" engine with 1000 miles on it. Don't want to pull the head unless I have to, or replace the oil pump unless it is bad. Anyway to identify the specific reason for low oil pressure, i.e. other locations to check oil pressure? [img]images/graemlins/confused.gif[/img]
sammyman is offline
post #2 of (permalink) Old 04-15-2004, 01:58 PM
Re: Oil Pump Plugs
the pressure should be the same pretty much everywhere in the motor sounds like a bad pump or a bad rebuild
szki272 is offline
post #3 of (permalink) Old 04-15-2004, 08:42 PM
Nowhere's Avatar
Re: Oil Pump Plugs
Have you changed the oil and filter?
Nowhere is offline
post #4 of (permalink) Old 04-15-2004, 10:08 PM
Re: Oil Pump Plugs
Take the valve cover off and start it up . You should see oil circulating to verify that the head gasket isn't in backwards . Shouldn't take more than a few seconds to see the oil flowing into the drains . If the pump was installed and the gasket allowed to slip or pump not rebuilt correctly could cause this problem also . Or, some yak really fubarred the fitment of the crank ....or cam , ect....
Sarge
Sarge is offline
post #5 of (permalink) Old 04-16-2004, 03:02 AM
Journeyman
BigElecCat's Avatar
Re: Oil Pump Plugs
The plug on the side of the oil pump housing covers a coil spring and little piston that serves as relief valve, in case the oil filter becomes clogged, and the pressure shoots way up. Did you use the Suzuki original sending unit and hook it to an aftermarket electrical oil pressure guage? If so, you probably got an inaccurate reading. My high mileage 1.3 stills produces 100PSI at mid to upper RPMs and 25 PSI at idle when the oil is hot.
BigElecCat is offline
post #6 of (permalink) Old 04-16-2004, 07:28 AM Thread Starter
Re: Oil Pump Plugs
Changed oil and filter. Removed factory oil pressure switch and threaded in aftermarket mechanical oil pressure gauge. Readings: After warmup <5lb at idle, 28lb at 3000 rpm. Did peak once at 38lb. while semi cold.
sammyman is offline
