forum answers not helping - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-05-2004, 08:44 PM
wayner
Hi everyone,
Just joined up. This is my first post.
I have a 91 Samurai with a 1.3L TBI. The problem is high idle and surging when warmed up. I did search and tried some of the answers but none have worked.
My check engine light is on but I get a code 12. I have replaced the TPS and the MAP sensors. All plug, wires, cap & rotor are new.
I plugged the passageway in the piece with the wax ball and it brought the idle down but it increases as the engine warms. I also turned the washer with the nubs on it clockwise. I must have turned that thing a dozen times with no effect at all. Ive sprayed carb cleaner all over the place but can not find any vacuum leaks. Anyone have anything else I can try. I would really like to fix this myself and not take it to a dealer. The nearest dealer is over fifty miles away. The local repair shop couldnt figure it out.
post #2 of (permalink) Old 04-05-2004, 09:19 PM
Re: forum answers not helping
Use the gas from an unlit propane torch to test for vaccum leaks. Sounds like that may be your problem.
AkDale is offline
post #3 of (permalink) Old 04-06-2004, 05:04 AM
wayner
Thanks Akdale
I will give that a try, hopefully today after work.
post #4 of (permalink) Old 04-06-2004, 09:00 AM
I assume code 12 is "no problems"? whats on the odometer? sami's click the engine light on
at 50 or 60 K debending on the year. there is a reset switch on the collumn on the pre 88.5
models. and I think I remember the post 88.5's switch being behing one of the speakers?
outlawmws is offline
post #5 of (permalink) Old 04-06-2004, 01:39 PM
Outlaw, that switch behind the speaker is on a tracker or sidekick. The ones on the sammy are still in the same place.
ka4yqi is offline
post #6 of (permalink) Old 04-06-2004, 02:00 PM
Yep, Too many things to remember these days... Thanks ka4yqi
post #7 of (permalink) Old 04-06-2004, 03:33 PM
Hmmmm........................sounds like singed eyebrows to me. Got 911 on speeddial [img]images/graemlins/grin.gif[/img]
AZtoyguy !! is offline
post #8 of (permalink) Old 04-07-2004, 02:35 AM
Don't need it, Been doing that for years. Never had a problem.
The breeze created from the rad fan disperses the small flow of propane and it would be very hard for it to flare---- All it would do is ignite the torch. Think about it. Hmmmmm.
AkDale is offline
post #9 of (permalink) Old 04-07-2004, 11:42 AM
Called the "Propane trick" for search purposes.
Using propane to find vacuum leaks is common with professional shops that understand how to do it. Those that don't just throw parts at it until they find it or you go broke.
The trick to finding an air leak is to use something that burns similar to gasoline but won't burn the vehicle down. Some folks use carb cleaners that don't burn, WD-40, oil, or other chemicals that don't burn, even water. They don't do anything. At best they might temporaily plug the hole.
Spraying starting fluid or gasoline is very dangerous.
When a burnable substance hits the leak it causes the engine to speed up - if it was lean in the first place.
Propane is the safest and easiest thing to use.
Prepare the engine - if it's possible, lean it out even further, and slow it down as much as possible. A slow running engine with a very lean condition becomes very sensitive to adding a tad more fuel - the propane.
Take off the torch head itself, slip a long hose over the tube. It's best to remove or drill out the tiny orfice as well, to get even more propane volume.
Use the end of the hose to spray around possible leak areas -- when you hit a spot where air is not supposed to be getting in the engine RPM will increase. To make sure you know how it will react, give a little down the carb/TBI throat and notice.
You can get it in areas that are hard to reach, even harder to see - like under the intake manifolds, etc.
Try not to spray it on the distributor - there's sparks in there.
If it does ignite it flashes, scares hell out of you, but then the fire goes out. If you'd sprayed carb cleaner or gasoline around you'd have wet puddles and a big fire.
Remember, propane is heavy - it will collect in low areas.
And, sometimes the air blowing around the engine compartment can blow the invisable propane down the carb tricking you -- "Look - the fender's leaking." Use common sense.
Propane enrichment is standard operating procedure for almost all car makers.
And -- it's a great way to tell if your mixture is correct.
Normally a correct mixture will have a very slight reaction - both at idle or high speed. It should be very slightly on the lean side - meaning adding a very small amount of propane will cause the RPM to increase a tiny bit. Then adding even more propane will cause it to slow down - as it becomes too rich.
You can do that test at any RPM - even at 6000+ if you want. It'll tell you how your jets are - too big, too small etc.
Anything above idle you will have to drill out the torch's orfice to get enough propane.
Poor man's dyno -- Run the hose from the driver's seat into the engine's airstream and drive it - add propane under load to see if you can stand more jetting or less.
It's great for diagnosis too. Fuel vs Ignition? Lean or Rich?
Some folks mistakenly think propane will hurt an engine, but many vehicles use propane all the time. It's just another temporary source of fuel.
Some think it will burn it up because it's too lean - like
Nitrous - no, Nitrous Oxides make it go lean, propane goes rich - just the opposite.
I've even used it to drive my van a few bocks to the gas station in the rain when I ran out of gas.
It's probably the handiest diagnostic tool you can have in your shop short of a scope, exhaust analyzer, and dyno --- and many many thousands of $$$ cheaper! Even then I used it in combination with all that equipment in my shops.
RRich is offline
post #10 of (permalink) Old 04-07-2004, 12:21 PM
Yea---- What he said.
That is some great info!!
I never thought about checking the jets and mixture with it.
Makes sense.
AkDale is offline
