-   -   Anyone running 33inch tires wider than 12.5 inch? (https://forums.off-road.com/suzuki-geo-all/183931-anyone-running-33inch-tires-wider-than-12-5-inch.html)
CorvetteChris 01-01-2004 07:49 AM
I am looking to put 33s on my Sami. 31s are just not big enough (now). I have 12.5" wide tires on 10 inch wheels and I see that 33x14 looks like the only other size available?
If you are running 33s, what tcase and or gears do you have?
Thanks
NC_Zuk 01-01-2004 08:28 AM
Re: Anyone running 33inch tires wider than 12.5 inch?
Either the Swamper LTB or TSL also come in a 33x13.5. And of course the Bogger comes in 33x14. Just open a 4wd mag, there are so many advertisements in there for tires and they all list tire sizes. Best of luck!!
Oh, I run 33x14x15 Boggers on my Sammi with a RRO 6:1 t-case. On the trail it is AWESOME!!. On the street I need help! I have a 1.6 8v in there but I really should consider some 4.62's. Maybe too deep though. Woat would be ferfectr though would be the 4.10's in Toy axles. I think this would be the perfect gear for 33's and a 6:1 t-case.
szki272 01-01-2004 10:57 AM
Geoff on here is running 33x14.5 super swamper ssr http://www.off-road.com/suzuki/reviews/interco.htm
I think I saw some 33x16 or 33x16.5 super swampers at lesschwab a couple months ago
rockrat 01-01-2004 11:17 AM
I dont think that would be to deep Art i ran 4:16 with 4:57 r/p and the 1.3 was ok off raod but needed alot more on the street
aftermarket4x4 01-01-2004 05:15 PM
I have the 33X15.50 Swamper SX's:
http://members.cox.net/aftermarket/000zukiblack.jpg
They are great tires....LOTS of traction!
I run the 5.12 gears with hybrid rear and 4.16 T-case....ho and a 1.6 16 valve.
Tires are for sale $$$$$400 or $550 15X10 w/wheels....3/4 tread front and below 1/2 tread in rear.
Sean
szki272 01-01-2004 05:42 PM
I want to say with the 6 to 1 gears and 4.62 gears you will run about 5000 rpm at 65
CorvetteChris 01-01-2004 05:58 PM
Sean, those are on 10 inch wheels? You running stock sami axles and have no problem with clearance to the springs? That is mostly what I am concerned about.
My axles have the stock gears and I am running 4.16 t-case. At 70 mph I am about 4300 rpm. I was hoping that by switching to 33s, I would drop my rpms to something like 3500 and still be OK with the 1.6 16v motor??
CorvetteChris 01-01-2004 05:59 PM
Btw, I don't want to go with boggers again because they are so damn dangerous on the road when it rains!!
Believe it or not, the Sami is my daily driver, 38 miles a day!
aftermarket4x4 01-02-2004 06:52 AM
The 33X15.50's did rub on the springs on the stock width Samurai front axle so I installed a set of 1.25" wheel spacers which easily cured the problem. They are also alot smoother/quieter on the road than you would think....500% better than a Bogger on the road and almost as good in the mud and awesome in the rocks!
If you run stock differential gearing and just the 4.16 T-case you will be just a little bit under geared, but it would really be fine on the highway. I run 5.12's and the 4.16 t-case and I am really over geared for the highway. Optimally I would recommend running a 4.30 or a 4.62 gear in the diff's. You could also just run all T-case gearing, but that does put alot of stress on the driveline.
Sean
