Electric Radiator Fan - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-05-2003, 03:12 PM Thread Starter
Can anyone tell me where I can find a write up for putting in an eletric radiator fan.
Thanks
Lil_Mudder is offline
post #2 of (permalink) Old 12-05-2003, 04:20 PM
Mud_zuki
Re: Electric Radiator Fan
I should take a fan from a peugot. they are front mounted from the beginning.
my frends drive with fan's from SAAB 99/900 series.
personly i'm gona have a peugot fan.
// Tobbe
post #3 of (permalink) Old 12-05-2003, 05:04 PM
I put one from a 90's civic (ac fan) in. I didn't use a write-up kinda just went into place. Probably took me fifteen minutes not including running wires up to the dash, so maybe 40 minutes start to finish.
CTBrent is offline
post #4 of (permalink) Old 12-05-2003, 05:06 PM
87zuke's Avatar
I am planning a write-up and have all the pix for it and can probably answer questions. I used the flex-a-lite kit with the adjustable thermostat. Do a search. Crow,pug and others helped me out when I did it in the summer. Jim
87zuke is offline
post #5 of (permalink) Old 12-05-2003, 06:52 PM
Journeyman
Ben_T's Avatar
I used a fan from a `90's Subaru legacy turbo. Fits like it was made for the job, and cost me $16NZ (about $10 us). It just need an extra 40mm sheet metal strip down one side for mounting. It used a couple of the stock bolt holes, and drilled 2 new ones.
I got a thermo switch from a G13a Suzuki Swift, and made a boss that was pressed into the themostat housing.
I wired it up with a relay, and an iluminated switch to turn it off for water/mud crossings. The light comes on when the fan is manually switched off so that you don't forget to turn it back on and cook the mota.
It's a two speed fan, but I just wired it to run at max speed, and it blows like hell. I think the zook would just about move under fan power if I left the handbrake off!
Oh yeah, I just installed a Warn 8274 winch, and it takes up most of the area in front of the radiator, but the fan still keeps the motor cool.
Ben
Ben_T is offline
post #6 of (permalink) Old 12-05-2003, 09:04 PM
DannyL's Avatar
I made a boss that was pressed into the themostat housing
Can you explain that?
DannyL is offline
post #7 of (permalink) Old 12-05-2003, 09:29 PM
He just bored and press fit a threaded boss into the top of the thermostat housing . You could use the temp switch hole right below it and rethread it ...
Sarge
Sarge is offline
post #8 of (permalink) Old 12-05-2003, 09:32 PM
Nowhere's Avatar
With the switch up top seems the fan would only be prone to running only when the thermostat begins to open regardless of the engine temp. Seems ok either way.
Nowhere is offline
post #9 of (permalink) Old 12-06-2003, 09:03 AM Thread Starter
I can't really see the hole underneath. Could you be specific as to were it is? I will check it out on my 1.6 but just incase I have difficulty some guidance would help.
I don't know that I could just leave the electrical fan attached to a switch. I would think that one time or another I would just forget about it and then theres goes the motor.
post #10 of (permalink) Old 12-06-2003, 11:54 AM
Has anyone installed a temp switch to an idiot light on the dash?
When I was playing around in the gravel pits of Badlands at the '03 Melt, I had to keep an eye on the temp gauge. I never had a problem with overheating before, but I guess the combination of high RPMs and the heat of the summer sun coming off of the sand was a bit too much for the stock fan.
I was thinking of rigging up a temp warning light, something that would be bright enough that it could not be overlooked. Anybody else ever try this?
JerseyZuks is offline
