EGR valve on 16V motors -- diagnosis questions? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-30-2003, 10:23 PM Thread Starter
The "check engine light" keeps illuminating on my '96 Tracker. I checked and the motor is still there ... but the code indicates an "error" with the EGR system. I'd like to remove and clean the EGR valve but it's mounted at the rear of the motor next to the firewall. I think I can get wrenches on it and the EGR pipe. A new valve is $200-something !!!
Anyone with experience removing, cleaning or replacing the valve? I've already checked -- the diaphram moves when it's cold. I haven't checked it while it's hot because it get's a little too warm -- it appears to move if I use a long screwdriver as a probe, though. There's one vaccum hose attached to the valve that appears to be intact.
The light comes on when it's colder out (50ish or less) and seems to come on more frequently when it's moist out. I reset the light and everything is fine, then, usually when I let off the gas while travelling, it relights. Any ideas? It codes the same all the time. Last winter, I left it on the whole time and come spring, reset it and it stayed off until the cold weather.
Thanks for any suggestions, advice, pointers .....
panewstoo is offline
post #2 of (permalink) Old 11-30-2003, 11:39 PM
ackerdackerly's Avatar
Re: EGR valve on 16V motors -- diagnosis questions?
You may need to use a 10mm socket with a u-joint to get at it. You can also unbolt the fuse box mounted on the passenger strut tower to make some more room.
If it was like my retired 1.3 head and EGR valve, you will discover that carbon has built up in the passage in the head to the EGR valve along with the EGR valve itself. Sort like the carbon version of hardening of the arteries...
Careful cleaning of the unmounted EGR valve (using only solvernts! -- no pokey things!) will help. Careful cleaning of the passage (which starts on the other side of the head where it connects to the exhaust manifold) will also improve things, but requires major disassembly or patience, solvents and some pipe cleaners to be done right.
Hope this helps!
ackerdackerly is offline
post #3 of (permalink) Old 12-01-2003, 06:53 AM
TomKat's Avatar
Be sure your fault isn't for an egr POSITION sensor. They were notorious for failing/ sticking.
TomKat is offline
post #4 of (permalink) Old 12-01-2003, 05:42 PM Thread Starter
Ack & TomKat:
Some very useful information you guys have provided to me. I'm interested in removing the valve and checking for the carbon buildup and cleaning out whatever I can to see if it doesn't help things out.
TomKat: I'm particularly interested in the EGR position sensor. Can you tell me more about this? Where is it? What can be done to check it? Is there a "resistance check" to make sure it's operating correctly?
Thanks to all for reading and, especially, for the helpful insights you've provided !!!
