4.3 Vortec conversion questions... - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-24-2003, 05:36 PM Thread Starter
Well I haven't been on this forum for a looooong time. Anyway with all my other projects finally completed, I can now get started on my Samurai. I have a 2000 4.3 V-6 out of an S-10. I got the harness from FI.com, so I'm good there. I'm still debateing on which tranny to use. I have a fresh TH350, but I really want the OD gearing of the 200R4. This question is to you guys that have done this conversion already. Is it neccessary to lift the body for clearance ?? If so how much ?? I rather not lift the body, then again I didn't want to clearance the body either. I pulled the body off in order to reinforce the frame. If a body-lift is neccessary, I'll build new body mounts with the lift in them already. Also how you 4.3ers tranfers cases' holding up ?? I was told by different places that they hold up well with a slush box no problem. Anyway if you guys got a second, give me some info....Thanks !!
John [img]images/graemlins/confused.gif[/img]
Restored64 is offline
post #2 of (permalink) Old 11-24-2003, 07:09 PM
Re: 4.3 Vortec conversion questions...
I was thinking of a 4.3 swap last month when I ran across a 2000 4.3 for $300. After some reserch I saw either a 2" bodylift or major tranny tunnel reconstruction was in order to fit the 200R4. I also read that the front driveshaft comes in contact with the trans. pan which needs to be modified. All of these things can be fixed by someone with the right skills, I just didn't want to run a bodylift or cut my floor up.......yet [img]images/graemlins/grin.gif[/img]
by the way...welcome back
zuk88 is offline
post #3 of (permalink) Old 11-25-2003, 04:01 PM
i just bought an "88 that had a lightning conversion kit swap done years ago--has been used mainly for street up until now. here's what i've found so far:
--mine has a spoa & a 3" body lift--& has 32x11.50 bfg at's. i'm gonna raise the motor mounts & trans (2004r)mounts up about 1.5" a& rework the t.c. bracket that lightning conversions supplies to raise the t.c. up about 3"
i don't see where the body lift is necessary & don't beleive the tunnel will have to be reconfigured.
--as zuk 88 said, the clearance between the front shaft & trans pan & also between the front diff & oil pan is tight--mainly because i have sagging springs. i'm gonna go either rears up front & cj rears or wrangler all around & fab my own mounts with the idea of moving my front axle forward at least 1.5" to help with the oil pan clearance problem. i think the front shaft will clear the trans pan fine once i get some lift back.
--with the 32's & stock gearing i'm turning about 2800rpm at about 72 mph--if you use a th350 you're gonna be turning very high revs at hwy speeds due to the t.c. reduction unless you run 35's. i plan to run 33" swampers which should lower mine about 200 rpm or so.
--from the little i've driven mine so far--all the headaches will be worthwhile --the power is GREAT!!!
GOOD LUCK!!!
frank
cueball is offline
post #4 of (permalink) Old 11-25-2003, 04:14 PM
can you take a bunch of pictures for me and send the to [email protected]
GA_ZUKI is offline
post #5 of (permalink) Old 11-25-2003, 04:20 PM
yes, but it'll probably be this weekend before i can do it. any thing in particular you want pics of?
frank
cueball is offline
post #6 of (permalink) Old 11-25-2003, 04:27 PM
everything you can think of
then the rest of it LOL
starting to collect all info for the same thing
GA_ZUKI is offline
post #7 of (permalink) Old 11-25-2003, 04:42 PM
frank
cueball
88 w/4.3
I'd like to see pics of a 200R4 in a stock trans tunnel with no bodylift....LOL [img]images/graemlins/grin.gif[/img]
zuk88 is offline
post #8 of (permalink) Old 11-25-2003, 08:02 PM
zook
i have a 200r4 if you need one, pluss all of the other parts that you need to make the trans work.
post #9 of (permalink) Old 11-25-2003, 08:25 PM Thread Starter
Very interested in the tranny!!! What "other" parts are you talking about ?? Where are you located ?? You can e-mail me direct if you wish. Thanks !!!
post #10 of (permalink) Old 11-26-2003, 05:03 AM
nitro92v
I'm with cueball, you don't need a body lift to fit the 200 tranny in place. I have the 4.3 conversion in my 87' with no tranny tunnel work done. The only thing you need is a small hole in the tunnel near the transmission coolant lines.
Brian
