Motor questions Could the rings be bad? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-04-2003, 02:35 PM Thread Starter
I am working (or about to) on my cousins Samurai. It smokes pretty good and I am wondering if it needs a full rebuild or just the head with valves redone. What kind of checks can I do to tell me if the lower end is ok. Will a compression test at the spark plug hole tell me if the bottom end is good or will it just tell me if there is compression loss in the heads. The spark plugs all look carboned up with some oil residue on a couple of them. I am going to study my manual tonight....Any input would be appreciated. I was thinking of putting a rebuilt head on it if possible.
Mark
markmartinbirdie is offline
post #2 of (permalink) Old 10-04-2003, 09:39 PM
daxe's Avatar
Re: Motor questions Could the rings be bad?
What your cousin's samurai needs is a qualified mechanic.
~daxe
daxe is offline
post #3 of (permalink) Old 10-05-2003, 09:08 AM
Does it smoke on start up, or all the time? If it smokes on start up then it's the valve seals but if it always smokes then it's the rings.
4x4_Austin_Mini is offline
post #4 of (permalink) Old 10-05-2003, 09:19 AM
When you do the compression tests, make sure you run two seperate tests. The first one is called dry. The second is called wet, it is called wet because you squirt oil into the plug hole. If the rings are worned the additional oil will help seal the piston. If no change then the top end is the culprit.
There are others here that can give you a more specific break down of indications.
txgocart is offline
post #5 of (permalink) Old 10-05-2003, 09:37 AM
TomKat's Avatar
[/ QUOTE ] That's a procedure that is a good indicator of a driveability issue but i have many times seen a broken or sludged up oil ring(s) causiing excessive smoke that has had a nearly perfect and even compression test. IMHO, don't freshen up the top end and leave a weak bottom end. It's like washing toilet paper.
TomKat is offline
post #6 of (permalink) Old 10-05-2003, 10:23 AM
I did that [img]images/graemlins/chair.gif[/img] UHHHH that is the new top end with old bottom end,~~~~ Not the toilet paper thing [img]images/graemlins/blush.gif[/img]
I actually put on a $600.00 Reynolds HP head on the old bottom end, but in my defense the cam had seized on the old head so I had to have one NOW and things are still a work in progress!! [img]images/graemlins/grin.gif[/img]
OLDCODGER is offline
post #7 of (permalink) Old 10-05-2003, 10:36 AM
Nowhere's Avatar
AAAAAAAAAAAAAAAAAAAAAAAAAAAHAHAHAHAHAHA!
Call around to shops, get quotes for a "leakdown test", you might want to do a general compression test too (cheap, buy a gauge or have a shop do it).
Here's a good web site with info on a leakdown test.
[img]images/graemlins/laugh.gif[/img]
Leak down test.
Nowhere is offline
