I give up, where's the O ring - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-29-2003, 07:44 PM Thread Starter
I give up, where\'s the O ring
Starting to leaak a little oil around the dist. Need to replace the O ring. The FSM shows an O ring around the dist. shaft. Is that the one? Or is there another one in the housing itself? [img]images/graemlins/confused.gif[/img] [img]images/graemlins/confused.gif[/img] [img]images/graemlins/confused.gif[/img]
ZippytheZuke is offline
post #2 of (permalink) Old 09-29-2003, 08:13 PM
Re: I give up, where\'s the O ring
here ya go
Make a reference mark on the distributor where it connects to the distributor housing. Also make a reference mark on the rotor so you can line everything up when reassembling everything.
Remove the vacuum line and the yellow plug from the distributor.
Remove the 12mm bolt that holds the distributor to the housing.
Pull the distributor from the housing.
Remove the three 10mm bolts from the housing.
Remove the housing from the head. A small amount of oil will leak out when you do this.
Replace the o-ring on the distributor and the one on the distributor housing.
Reconnect the housing to the head. Be sure to reconnect the ground wire.
Pour a small amount of oil into the housing so that the gears aren’t dry when you start the motor.
Reinstall the distributor to the housing making sure to line up your reference marks.
Reconnect the vacuum line, yellow plug, and cap. The motor should start as long as you lined up the reference marks. We recommend that you check the timing now.
GA_ZUKI is offline
