tranny question... - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-28-2003, 11:34 AM Thread Starter
Jbird's Avatar
tranny question...
1988.5 Zuk with 156,000 miles
Tranny oil was changed in the Spring
Lucas oil additive was used with cheap 80-90w oil
Tranny is blowing oil out durring long trips. Looks like its coming out around the gear shifter.
The vent is routed into a hose that is run into my Snorkel. (all of my vent tubes are run into the snorkel)
Possible problems....
1. Oil is foaming and therefor taking up to much space...resulting in some oil overflowing out the gear shifter.
2. Having the vent plumbed into my Snorkel is having an adverse effect that I'm unaware of. Resulting in oil somehow overflowing out the gear shifter.
Anyone have any other thoughts or ideas or suggestions???
We're not talking about losing a quart of oil...it's just enough to wet the sides of the tranny and drip a little bit on the ground after the Zuk is parked.
I do not notice the problem when just driving around town and short 15 minute rides.
Thanks!
Jay
Jbird is offline
post #2 of (permalink) Old 09-28-2003, 04:23 PM
Re: tranny question...
It sounds like it's not vented properly. The around town thing gives it away. At high speed the snorkel is probably getting a positive air pressure boost. Do you have the opening facing the front?
gi_zuk is offline
post #3 of (permalink) Old 09-28-2003, 09:42 PM
ackerdackerly's Avatar
Here's my theory:
If you have your tranny vented to the snorkle, I would think that the snorkle might be causing an effect like an atomiser (like in a paint airbrush) from the movement of air to the carb/TBI. such an arrangement would generate a negative air pressure (vaccuum?) in the transmission case.
The resulting change in pressure inside the transmission case may be causing air to be sucked in through the shifter mount. Air moving through transmission while the engine is running at high RPMs (ie highway driving) might be causing the foaming. When you stop, the foam is redistributed in the transmission (remember, it is created by air drawn through the shifter mount hole so the foam is 'sucked' away from that location...) so that some of the foam flows out of the shifter mount hole onto the transmission and ground until the foam dies down.
Plausable?
Solution:
reroute the vent tube to some other location that does not not provide a negative pressure on the transmission vent. Or the differential vents.
ackerdackerly is offline
post #4 of (permalink) Old 09-29-2003, 03:22 PM Thread Starter
Jbird's Avatar
I think I'm going to try and re-route the vent tube....I'll let you know how it goes....
Jbird is offline
