hi steer questions - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-28-2003, 10:17 AM Thread Starter
hi steer questions
i have a question for the hi steer
i have looked at the breeze setup and its ok here are the questions
can i not incorperate the bottom to hang over the kingpin area and use longer bolts to tie this in
also it still leaves the under the springs cross piece
the mercedees arms are not flat they rasie the piviot up another inch or so higher than breeze and higher over stock
could you not raise it up with something like breeze on both sides and bring the cross over piece up as well then tie in a piece down to the stock location so it would be attached at the calipers and the king ping and the stock location or leave out the king pin over hang
the prob with the benz is it push pressure much higher and off of the piviot point
would it hurt anything if you just went with the caliper mount and the down piece to the stock area
below pics from breeze and the benz hi steer
GA_ZUKI is offline
post #2 of (permalink) Old 09-28-2003, 10:34 AM
Re: hi steer questions
Here is my version of my Yota high steer Yota high steer web page
OLDCODGER is offline
post #3 of (permalink) Old 09-28-2003, 10:44 AM
Nice tires!!! What are they??
post #4 of (permalink) Old 09-28-2003, 11:24 AM Thread Starter
dont know not mine
here are mine
GA_ZUKI is offline
post #5 of (permalink) Old 09-28-2003, 11:31 AM Thread Starter
something like that
GA_ZUKI is offline
post #6 of (permalink) Old 09-28-2003, 05:23 PM
daxe's Avatar
tires are Simex Jungle Trekkers
~daxe
daxe is offline
post #7 of (permalink) Old 09-28-2003, 10:21 PM
Not to change subjects but the simex tires are nice looking and available in a 34x11.5 . Wonder if anyone imports them ?
sammi_davis is offline
post #8 of (permalink) Old 09-28-2003, 10:27 PM
one other thing to not about the mercedes arms is that they also mess with the ackerman angles.
post #9 of (permalink) Old 09-29-2003, 07:26 AM
daxe's Avatar
according to what I was able to gain on the web, Simex tires are very expensive. They have "Armored" sidewalls, whatever that means.
Maybe start a thread in here with Simex tires in the title and some of the UK guys will chime in with info. OK..I'll do that now. Glad I suggested it.
~daxe
daxe is offline
post #10 of (permalink) Old 09-29-2003, 08:59 AM
The Ackerman angles mentioned are well depicted in your second pic of the Breeze setup. (The orange
arm) The stock tierod, the part that matters to Ackerman, is set well outside the kingpin axis. The
breeze is set well inside. 0 deg Ackerman would be somewhere between the two.
Many race cars run 0 deg Ackerman, but they are steering with the throttle and want the front wheels
pointing the direction they want to go, a very different and extreme way of driving.
If the tie rod was behind the kingpin instead of in front, you would want it about as far inside as you
see the Breeze arm positioned, only behind. The Mercedes arms are about the same deal and angle
as the Breeze. The Breeze gets away with it only because its the drag link instead of the tie rod, no
Ackerman is involved. The Mercedes does affect Ackerman since it also positions the tierod.
The thing preventing a correct Ackerman angle with Hi steer is the disk brake rotor and tire/rim is in the way.
To get it tha high, it gets into interference with those parts.
outlawmws is offline
