suzuki to geo - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-24-2003, 05:24 AM
tracker92
suzuki to geo
what is the big difference between suzuki and geo, why wont the diesel kit work for the geo like it does in the suzuki so well? they are the same body and drive train arent they? are the motor mount and bellhousing that differnet?
post #2 of (permalink) Old 09-24-2003, 07:32 AM
Re: suzuki to geo
The diesel kits are for the Samurai. Although grapevine says they are working on one for the Track/Kick
post #3 of (permalink) Old 09-24-2003, 04:16 PM
tracker92
Re: suzuki to geo
i know there for the samauri but what is the difference between them and trackers, arent they all the same motor, drivetrain and axles, they need to make things unverisal, i like alot of things samarui/sidekicks have that you cant get for geo's i wish they would come out with a kit for geo, i would like a front locker also
post #4 of (permalink) Old 09-24-2003, 04:31 PM
Re: suzuki to geo
The sidekick and tracker are the same with trim changes. It's the sami the is different with somewhat
different drivetrain.
outlawmws is offline
post #5 of (permalink) Old 09-24-2003, 04:57 PM
ackerdackerly's Avatar
Re: suzuki to geo
The Samurai is completely different from the Sidekick/Tracker.
A Samurai has:
-Solid axles.
-Spring suspension.
-Trucklike frame that makes the vehicle ride higher off the ground
-Was only available in the US with a 5-speed manual transmission.
-Was only available with a 1.3 liter engine.
- Has a divorced transfer case.
- only came in two versions - a 2-door convertable and a 2-door hard top (known as a "tintop").
The Sidekick/Tracker has:
-Coil spring suspension
-Independent front suspension.
-automotive-like frame that allows the vehicle to sit lower to the ground.
-Is/was available with a 5-speed manual transmission and a 3-speed automatic transmission
-Was available with a 1.6 8-valve engine and a 1.6 16-valve engine (newer versions have larger 4-cylinder engines).
-Has an "integrated" transfer case.
-Was available as a 2-door soft and hardtop along with a 4-door hardtop.
About the only thing that might be easily swapped between a Samurai and a Sidekick/Tracker are the stock wheels.
A visit to a local used car lot might be helpful in your quest for knowledge although finding a Samurai may be a difficult task.
Hope this helps!
ackerdackerly is offline
post #6 of (permalink) Old 09-24-2003, 05:30 PM
Re: suzuki to geo
I thought the tracker had a real truck frame? At least my buddy's 94 does. [img]images/graemlins/AR15firing.gif[/img]
post #7 of (permalink) Old 09-24-2003, 08:03 PM
Re: suzuki to geo
Here is what I mean:
Both are frame/body (as opposed to unibody) construction.
The Samurai has a frame made from two box beams bent and cross-braced in a ladder format.
The Sidekick/tracker frame is made from six pieces of boxbeam welded together to form a frame that lowers the passenger compartment (and creates a safety crush zone, I suppose).
