Damn chop saw keeps throwing breakers!!!!! AhhH! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-21-2003, 07:31 AM Thread Starter
I hate this tool. Not only does it cause a mess when using it, it's loud as hell, and stinks, it also KEEPS throwing the breaker at the panel!!! I've had enough. Anyone have any ideas? It's not a great unit (King Canada brand) but it was cheap, and yup, I got what I paid for [img]images/graemlins/smirk.gif[/img] But it has a 15 amp motor and ??? HP. Not sure. I know that until you get into the more powerful ones, they're all about the same. Question is: why does it keep doing this???? I don't lean into it; I just barely push down on it and when a couple seconds pass.....boom. No power. It just seems so gutless.
I don't think it needs a higher amp circuit: would that just fry the motor? Any ideas/input?
Cheers,
Steve
Hemogoblin is offline
post #2 of (permalink) Old 09-21-2003, 07:54 AM
CrowHorse's Avatar
Re: Damn chop saw keeps throwing breakers!!!!! AhhH!
Is the circuit dedicated exclusively to the chop saw or are there other circuits that run off the breaker?
If you have other loads on that circuit, the 15 amps that the chop saw draws plus the addition loads would cause the breaker to trip (assuming that it's a 20a breaker)........
CrowHorse is offline
post #3 of (permalink) Old 09-21-2003, 08:14 AM
Unfortunately , those chop saws can do that on a lot of houses/shops . Check the wiring , and see if it is 14ga and the breakers are 15amp . If that's the case , you are trying to use the entire circuit's capability up all at once hence the breaker going off . That thing needs to be on a 12ga/ 20 amp circuit or you'll never win . Also, if you use a drop cord smaller than 12ga you're going to have the same problem as well .....
Sarge
Sarge is offline
post #4 of (permalink) Old 09-21-2003, 08:18 AM
Nowhere's Avatar
Yep, I agree on Sarge's post. You might want to run a 10 gauge outlet in the garage for multiple high power tools. The only extention cord that will work with my 110 welder is 50' long and 10 gauge, you gotta over power the outlets, they should never be your weak link.
What happens is you get a voltage drop from the breaker pannel to the motor, that inturn raises the amperage, therefore it trips the breaker. With a heavy gauge wire, there's very little drop, you get max power at the outlet with very little problems.
Nowhere is offline
post #5 of (permalink) Old 09-21-2003, 08:40 AM
yeap it my turn now
first off the 15amp chop saw is running with out a load.
when you add the load the amps go up
i have a ridgid from home depot it is 15amps i did an amp test and under no load it gets about 6 1/2 draw and under a load it will go up as high as 45 amps yes i'm for real 45 amps. the breaks in the homes that trip have to heat up then trip thats why you can over use them for a lil'bit.
i use it on a 20 amp circut and a 100' drop cord and it does get warm after a bit. if i plug it up to my 6 way first which has a 15amp circut braker on it it will trip because of the draw.
just use it with the proper size blade and a min. 20 amp circut with the shortest drop cord as possiable
GA_ZUKI is offline
post #6 of (permalink) Old 09-21-2003, 09:08 AM
Skip
Everything that has been said above is true. Plus as a circut breaker pops it arcs and wears. This causes the breaker to become weaker. Replace it with a 20 amp. It will fit in the same spot aas a 15. Don't use an extension cord. If you must, use at least a 10 gauge construction extension cord. Keep it as short as possible. When I wired my shop area I used 10 gauge wire instead of 12 and no longer have any of these problems.
Point of interest, a 15 amp motor will draw 125% on startup and can draw the mentioned 45 under load.
Electrical loads are one of my specialties
Good luck [img]images/graemlins/40BEER.gif[/img]
post #7 of (permalink) Old 09-21-2003, 09:15 AM
Pooh-Bah
DougO's Avatar
It can fit, but contious use, or just long enough use at higher then recomended amps for that wire will cause other problems .. like the wire heating up and possibly causing a fire .. if you have a 15A replace it with a 15A .. it was a 15A breaker for a reason
With the answer above, that surprises me. espically when reccomending that and not knowing the current state of the house wiring .. age, type of wiring aluminum or copper, how many other objects that are on that line ..
DougO is offline
post #8 of (permalink) Old 09-21-2003, 09:21 AM
sorry to differ but you cant just change a breaker [img]images/graemlins/cussing.gif[/img]
because the electrical codes require some specs
you can over size the wire but not the breaker
15amp is for 14 ga
20amp is for 12 ga
30amp is for 10 ga
40amp is for 8 ga
50amp is for 6 ga
so with this said if you change to a 20amp breaker please make sure the wire is big enough
and you can bigger wire for amp draw and voltage loss
i have a swimming pool that is a 15 amp circut but it is 200 foot from the house due to distance and the amp draw i ran a 20amp circut with a gfic plug for water and i used 10ga wire. the 12 ga sj wire i used (all one run) would stay warm so i went another size bigger and no heat now
the heat will break down the properties of the copper wire and could make for a major fire hazzard in the future
one again always over do things the first time so it wont cost you more money in the future in repairs or replacing
GA_ZUKI is offline
post #9 of (permalink) Old 09-21-2003, 09:23 AM
DougO
you type faster than me
GA_ZUKI is offline
post #10 of (permalink) Old 09-21-2003, 09:53 AM
Yes to most of the above posts.
If your wire is 12 Ga or better AND not too long a run, you can swap the beraker with a 20.
one last Item I didn't see: Is the receptical a 15 or 20? a 20 can take a std 15 amp plug, but
will also have one leg able to accept a blade 90 deg from the usual plug blade. these recepticals
are made with stronger contacts (as you will discover when you try to plug something in).
An undersized receptical can make a mockery of all your other wireing. Spend the 5 bucks.
outlawmws is offline
