steering question.... - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-21-2003, 12:11 AM Thread Starter
Long story short, to help the steering shaft fit around the header I took 2 of the little shaft U-joints and welded them together, it cleared it fine but requires the need to be braced to the frame in order to utilize the u joints to pivot, I believe I have heard of people doing this before but was just wondering if it sounds like a bad idea seeing as I dont have many other options besides running an external mounting steering box i.e. a scout II steering box...
studlybil03 is offline
post #2 of (permalink) Old 09-21-2003, 12:21 AM Thread Starter
Re: steering question....
Also I purchased a 1986 Ford F150 fuel pump, its an electronic external mounted pump, Im worried about it applying to a carbuerated motor? Will it work?
post #3 of (permalink) Old 09-21-2003, 06:59 AM
i know on the old early 70's ford ranger's they have a mid-shaft bearing
a u-joint with a brace in the middle
get a pillar block with a hole big enough fo the steering shaft mount it the the firewell to keep the end fixed and let the u-joints work
GA_ZUKI is offline
post #4 of (permalink) Old 09-21-2003, 10:06 AM Thread Starter
thats what I figured, Im gonna embrace it heavily and run it, but what about the fuel pump? Will it be to strong for a carbuerated motor?
post #5 of (permalink) Old 09-21-2003, 10:10 AM
i'm running a low press. auto zone pump 3 to 5 psi
i have a regulator on it down to 2 1/2 psi on the webber 1.6 8v.
LQQK at what the the motor and carb require and the make sure the pressure at the carb meets that then you will be fine
GA_ZUKI is offline
post #6 of (permalink) Old 09-21-2003, 10:51 AM
That fuel pump is to much pressure for a Carb.
ka4yqi is offline
post #7 of (permalink) Old 09-21-2003, 02:04 PM Thread Starter
will the stock samurai fuel pump work? What PSI pump should I go with?
post #8 of (permalink) Old 09-21-2003, 04:46 PM
If the engine does not have a place for a stock manual pump, go with a low pressure pump for the carb. Was the sammy fuel pump for efi? If so then there is to much pressure for the carb also.
ka4yqi is offline
post #9 of (permalink) Old 09-21-2003, 11:30 PM Thread Starter
Yes it was for EFI, then could I get maybe a pressure regulator and run it or a little 30 dollar fuel pump...
