Driveshaft - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-15-2003, 08:17 PM
Maniac
Driveshaft
I have a 5 inch SPOA with a YJ conversion on 31's and am having some problems. The front driveshaft is hitting the crossmember and the U-joint is hitting a bind. I've shaved it down about as far as it can go and still binds. What do you guys with your extreme hights and driveshaft angles do to fix it? I also have bad vibrations accelerating in first and 2nd. None of this happened till i put the YJ's on. HELP!
Thanks for the info,
Stefan
87 rag, 1.6l 8v, 5 inch SPOA, YJ, locker, 31's
post #2 of (permalink) Old 09-15-2003, 08:40 PM
Re: Driveshaft
put a 1 inch spacer on the t case if that isnt enough put some washers under the t case mounts to shim up the t case i have the poly mounts and shimed it 3/8 of an inch
szki272 is offline
post #3 of (permalink) Old 09-15-2003, 08:46 PM
Maniac
Re: Driveshaft
I have a 1 inch spacer and the transfer end, and a 3/4th at the other. That helps. but it still binds and has terrible vibs.
post #4 of (permalink) Old 09-15-2003, 10:36 PM
Maniac
Re: Driveshaft
Anybody got any ideas?
post #5 of (permalink) Old 09-15-2003, 10:43 PM
Re: Driveshaft
Heres a new product I just finished up allows you to cut the stocm x-member out if you want $70.00 minus rubber t-case mounts if mounts needed additional $19.
rockrat is offline
post #6 of (permalink) Old 09-15-2003, 10:51 PM
Maniac
Re: Driveshaft
post #7 of (permalink) Old 09-15-2003, 10:51 PM
Maniac
Re: Driveshaft
That may help with the vibs, I'll think about it. But what about the problem with it binding, even after shaving it as far as possible?
Stefan
post #8 of (permalink) Old 09-16-2003, 12:15 AM
Re: Driveshaft
Yes this will stop the bind on the x-member but the only way to get rid off shaft bind at the u-joints is to either clearence the u-joint or extend the front wheelbase, or get a shaft that has more deg. Like a rear yota shaft cut down.
rockrat is offline
