t-case - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-14-2003, 02:35 PM Thread Starter
t-case
<center>Well here's the update. I made new mounts and they worked great! I would say they will not break and they also replace the stock mounts. But the new news is that they hold so well I ripped the side of the t-case apart [img]images/graemlins/shocked.gif[/img] All the gears aren't hurt as far as I can tell. Does anyone have a good needs rebuilt t-case they would want to part with? I need that to get back on the road. And with the gear and tire combo that I have I am also going to get the Forest Bucket for this next time around. If you are wondering, I am also open front and rear with 3.07 in the axels.
grumpy is offline
post #2 of (permalink) Old 09-14-2003, 08:20 PM
Nowhere's Avatar
Re: t-case
Goooooooooooooooooooooooooooooood idea on the Bill Forrest "Bucket".
Nowhere is offline
post #3 of (permalink) Old 09-14-2003, 08:22 PM
Re: t-case
Here is my solution to the same problem . I used jb weld to fill the cavity and then used studs instead as they are stronger . I used red threadlocker to lock the studes in on top of it . I then installed it in a mighty kong to lock it all together .As of yet I have had no more problems with my t case !
sammi_davis is offline
post #4 of (permalink) Old 09-14-2003, 10:00 PM
Re: t-case
Hey Nick I forwarded all info to Bill, I rep it he sends it...
-Scott
rockrat is offline
post #5 of (permalink) Old 09-14-2003, 11:52 PM
camo_jeep
Re: t-case
Well, I guess that means you got it home OK,,,, it always gives me a sick feeling to see gear oil pouring out on the ground. Hope the gears arent hurt,,,, good luck,,,
post #6 of (permalink) Old 09-15-2003, 09:20 AM
billj
Re: t-case
Grumpy,
I would submit that at least part of the reason for the t-case explosion is due to the greatly unbalanced gear ratios that you are running in the t-case and diffs.
3.07 gears in the diffs provide little reduction at the driveshaft, therefore the t-case is seeing much higher torque loads than thru a "usual" setup.
Just for comparison, your final drive (t-case x diff) is 19.95. Mine, using a 4,89 t-case and 4,88 diffs, is 23,86, higher than yours and at the same time, with a lot less load being put on the t-case.......
HTH,
Bill
post #7 of (permalink) Old 09-15-2003, 09:54 AM
Re: t-case
I've got an empty (no gears) transfer case I'll sell for $35 if you're interested. PM me at [email protected]
later,
James
James Hiers is offline
post #8 of (permalink) Old 09-15-2003, 12:29 PM
Re: t-case
Got it [img]images/graemlins/grin.gif[/img]
Bill4rest is offline
