Diesel - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-24-2003, 02:39 PM
Zukiiwagon
Diesel
Howdy,
Nice site.
Finally got my 1.6VW turbo diesel running in my samurai. It sounds real nice, lots of torque too.
Anybody else here have a diesel in their zuke or going to install one? I'd like to hear about it, share info etc.
Phil
post #2 of (permalink) Old 08-24-2003, 02:44 PM
Nowhere's Avatar
Re: Diesel
Killer! Post some more info on the swap if you could! Did you buy a kit or make your own?
Nowhere is offline
post #3 of (permalink) Old 08-24-2003, 03:09 PM
Zukiiwagon
Re: Diesel
I used the kit from Roadless Gear. came with adapter plate(for stock samurai tranny), machined samurai flywheel to fit vw crank and a pilot bushing.
The engine is out of an '89 Jetta turbo diesel.
2 holes in the tranny have to be opened up. One ear on the engine block has to be built up with weld. for a new hole. The other side hole has to be pluged, and re-located.
You can use your stock clutch, works fine.
samurai starter can also be used, that's what I did. Turns the engine over no prob.
You need to fabricate your own engine mounts. I integrated the samurai mounts. Time will only tell how good they hold up, so far, so good.
Spring over is a must. Before I did the spring over the oil pan was only 2" above axle.
The oil filter housing will have to be swapped out for one out of a VW Fox since it is angle back, away from frame and engine mount.
Another thing, the VW exhaust is on the passenger side. If you're carefull enough it can be tucked right up in there.
Engine is a lot taller, so a body lift, or hood scoop, Or lower the entire engine and trany. Too much work just to get the hood down. I'm putting a scoop or raised section in mine.
Anything that's not clear I'll try to explain better.
post #4 of (permalink) Old 08-24-2003, 04:00 PM
Re: Diesel
Post some pics of you have them...I love this idea. and as soon as Colorado Springs Gets rid of the Smog testing I would like to do it.
post #5 of (permalink) Old 08-24-2003, 05:34 PM
Re: Diesel
post lots of pics
here also is a yahoo group on it
Samurai Diesel
GA_ZUKI is offline
post #6 of (permalink) Old 08-24-2003, 09:20 PM
Zukiiwagon
Re: Diesel
Thanks for the link,
Once I figure out how to post picks, I'll post em.
post #7 of (permalink) Old 08-24-2003, 09:23 PM
Re: Diesel
if you have troubles send them to me and i'll post them for ya
[email protected]
GA_ZUKI is offline
post #8 of (permalink) Old 08-24-2003, 11:16 PM
Re: Diesel Pics
GA_ZUKI is offline
