buying a 2.8 chevy Samurai Help!! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-05-2000, 08:51 PM Thread Starter
I am looking at buying a 87 Samurai that has been converted to v-6 chevy. I think it is the small one out of the
Camaro. It is probably a homade conversion but it looks okay. (I can get it cheap) The Transfer case is stuck in
neutral. It looks like they have prefabbed a short driveshaft from the auto trans to the t-case. It has spoa
so the clearance looks okay on the oilpan. Is there usually a problem with engine cooling? Looks like it
still has the SAmmy radiator. Any tips or problems related to this swap would be appreciated. He says tge
t-case is stuck in nuetral, Do you think I could get it in 2wd someway to drive it home? The body is rust and
dent free...And I can get it cheap. Let me hear your two cents or warnings THANKS
markmartinbirdie is offline
post #2 of (permalink) Old 06-05-2000, 09:14 PM
Re: buying a 2.8 chevy Samurai Help!!
The only problems I've heard of with the 2.8l is the crank. I personally havn't had much broblems with them and I've owned several of them(only one that blew the crank after over reving it). I'm interested in doing this swap myself is there anyway you can get any pictures of the swap? e-mail me at [email protected] with any details. BTW how much is it going for?
Adam
Big Bear,
I'm not crazy,I'm perfectly INSANE![img]/wwwthreads_images/icons/tongue.gif[/img]
Big Bear is offline
post #3 of (permalink) Old 06-05-2000, 10:10 PM
I have personally had an experience with the T-Case lever thing. It always seems to fail in nuetral when you try to shift between 4W LO and High. It is a quick and easy fix, but I do not see a way to drive it home (mine failed FAR away from home, with no other vehicles, so I tried). I ended up taking my transfer case out to fix it, but I think that I heard that you can fix it just by taking the lever out from the cab.(I don't know how though?) Anyways, it is a pretty easy fix, I wouldn't let it deter you from buying it, but I doubt if you will drive it home with out fixing it there. Just a little of my experience.
Marcus
http://www.izook.com/faq/faq_commonquestions.htm look at #5
post #4 of (permalink) Old 06-06-2000, 08:21 AM
pook
hi i also have been looking at puting a 2.8 in a zook so if you could post any pictures or fab. info it will really be helpfull.
or e mail me at [email protected] com .com
post #5 of (permalink) Old 06-06-2000, 09:18 AM
Sounds like the 'ol shifter sheet problem in the t-case. You can remove the shifter easily, and use a big flat-head screwdriver to pop the rail(s) back into place & it should be fine until somebody tries to shift it again.
Tim J
post #6 of (permalink) Old 06-06-2000, 09:06 PM
sounds like you're about to get a sammi at a steal. might want to keep the easy repair thing to yourself during negotiations..........
