SHOCK TOWERS - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-07-2003, 09:31 AM
Happy_Trails
SHOCK TOWERS
Whats a good "shock tower" to buy if going with longer shocks ???????????
do you have to relocate lower mounts ?
post #2 of (permalink) Old 06-07-2003, 10:13 AM
Nowhere's Avatar
Re: SHOCK TOWERS
Front or rear?
Are you going to modify/change the lower shock mount location?
On your tracker/sidekick?
IFS of solid axle?
Nowhere is offline
post #3 of (permalink) Old 06-07-2003, 10:38 AM
daxe's Avatar
Re: SHOCK TOWERS
Hey Alan,
In the front of mine I used a set of the "Ford Type" upper front shock mounts from Trail Tough. They are not only Ford Type..they are actual Ford parts with the Ford parts sticker still on them. Wildweasel welded them on for me, though they can be bolted, too. We tipped them backwards, similar to Trail Tough's instructions and with that setup and the lower mounts welded onto the YJ spring pads (SPUA, remember) a set of 26.5" extended shocks limits flex by a large margin. You will most definitely need longer shocks if you choose that route, especially since you are already SPOA.
In the rear, I opted for a Sky Mfg. upper rear shock mount that I got from Roadless Gear. This is a bar that goes side to side and bolts over the two existing rear shock mounts, giving you three choices of mounting the rear shocks. The outermost ones wouldn't work for me because they interfere with the exhuast and wouldn't allow for long enough shocks, either, though I understand from something Brent at Trailtough posted a couple weeks ago that you are better off using outer mounting positions if you are SPOA. The middle position was OK when i had 2" longer shocks but still had the potential of bumping the exhaust. I now have the same 26.5" shocks as the front, set into the mounts closest to the center of the truck. With the lower shock mounts relocated to the lower rear of the axle tube ala SPOA, and the 2.5 or 3" of total lift I have, these shocks are about 1.5 or 2" too long. There's not enough rod showing at the top. This may be less of an issue, however, since the shock travel is greatly reduced when they are mounted so far inboard on top. I am going to be adding in some add-a-leafs to give a little more lift and eventually replacing the shocks anyways, so this problem will get solved, too.
That upper shock mounting position also introduced a tendency for the shock to want to hit on the top of the differential upon compression, again because I am SPUA. Other people running YJs SPUA have reported the same effect. Cutting off the protective tube for the shock rod and getting the Ebrake cable off the top of the axle housing seems ot have solved that part of the problem.
hope this helps.
~daxe
daxe is offline
post #4 of (permalink) Old 06-07-2003, 01:26 PM
Happy_Trails
Re: SHOCK TOWERS
Nowhere.........
Towers would mean FRONT.
Think I asked if lower mounts need to be modified..maybe not.
90 samurai
post #5 of (permalink) Old 06-07-2003, 03:52 PM
Re: SHOCK TOWERS
Go to ford and buy the towers.. Mid 80's F250, I think I used 88.. they list at $11.20 Ea. Ordered them at the dealer and got them the next day.
Mini4x is offline
post #6 of (permalink) Old 06-07-2003, 03:57 PM
Re: SHOCK TOWERS
I cant find them that cheap... I have called a bunch of dealerships all around 40-45 per pair...still not that bad.
CTBrent is offline
post #7 of (permalink) Old 06-07-2003, 04:04 PM
Re: SHOCK TOWERS
I just started a thread on this topic at the beginning of the week. There are lots of pictures of my setup, which utilizes Ford shock towers up front.
Maybe this will help.
http://bbs.off-road.com/ubbthreads/s...mp;o=&vc=1
As for whether or not you have to relocate your lower mounts, that all depends on amount of lift, flex, length of shock and tire size.
Anton is offline
post #8 of (permalink) Old 06-07-2003, 04:19 PM
Re: SHOCK TOWERS
Hey Brent they are obveuosly looking up the wrong tower # I was quoted something similiar to you about 8 months age. I promptly told the guy he was smoking crack and to keep looking he then found the correct ones for $10.35 pc.
rockrat is offline
post #9 of (permalink) Old 06-07-2003, 04:29 PM
Re: SHOCK TOWERS
I use Jeep Wagoneers, three bolts and there on after you cut off the old ones of course..
tazuki88 is offline
post #10 of (permalink) Old 06-07-2003, 04:29 PM
Re: SHOCK TOWERS
My towers cost me CAD$21.69 each. Total came to CAD$49.45 and I got them the next day - much faster and cheaper than ordering them from the US.
The ford part number is E5TZ-18183-A.
Anton is offline
