T-case slips out of gear. - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-05-2003, 09:57 PM Thread Starter
Whats causing my t-case to slip out of 4 low?? 4 hi doesnt slip, but in low, i have to hold it in. Kinda sucks.
climberdood is offline
post #2 of (permalink) Old 06-05-2003, 10:27 PM
Re: T-case slips out of gear.
You either need a shifter sheet replaced under the shifter ball , or your sliding collar is shot on one side . If you've been running the 2lo mod , with just the center ball removed , that will do a lot of wear to the collar and cause them to pop out of gear ....
Sarge
Sarge is offline
post #3 of (permalink) Old 06-06-2003, 12:04 AM
Check your longside tcase mount. If it's bent it can cause the shifter to rub the body opening and put is out of gear.
I had that problem with mine. Turned out the long arm twisted on me. I straightened it up and welded some heavy gauge plate on it. No problems since.
mmartian1969 is offline
post #4 of (permalink) Old 06-07-2003, 08:51 AM
Nowhere's Avatar
Sarge, you're noting the cogg/collar that will disengauge and engauge the front driveline in a worn state will cause the truck to magically slip out of 4x4 mode into 2wd mode?
Hmph. I've had that happen to me like 2~3 times.
Nowhere is offline
post #5 of (permalink) Old 06-07-2003, 11:59 PM
Don't forget to check your oil levels...mine can tell me when its getting low by popping out...it is the only time it does it...also you might have a tweeked t-case arm casing binding under load, torn t-case mount...lots of things I believe.
