Whiney Transmission? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-13-2000, 03:02 PM Thread Starter
I recently bought another Samurai at a good price. Everything on the vehicle seems to be OK and all of the fluids are clean and full. The only problem is a whining sound, which I assume is coming from the transmission. It doesn't occur in first or second, but it starts a little in third. Fourth and fifth gears are the most noticeable. When I depress the clutch pedal the noise almost completely goes away, but I can still hear something until I stop moving. The whine is not that loud, I just want to fix it. FYI-- the Zuk is a '92 with 86,000 miles on it. Thanks in advance.
88.5 Samurai is offline
post #2 of (permalink) Old 05-14-2000, 08:30 AM
Re: Whiney Transmission?
... got the same problem on a 95 softtop w/ 35k miles...
it is more noticable at higher speeds, the whine's pitch only changes w/ speed but not w/ engine revs, its only noticable when there is "force" on the diff, (e.g. accelerating or engine braking) - thats why i am guessing the rear-diff /ring/pinon area is involved
its not really annoying, but its there... and it sounds like the whine you get in reverse (but far less pronounced)
... are we talking about the same thing??? )
bye
Alfred
Alfred is offline
post #3 of (permalink) Old 05-15-2000, 02:42 PM
Usually transmissions last quite a bit longer than that. Check your gear oil level. If its good, then your bearing are going bad. Do a rebuild on it before one schrapnels on your and takes out your gears..... then it gets REALLY expensive. Been there, done that.
http://www.rocky-road.com
post #4 of (permalink) Old 05-15-2000, 10:43 PM
if the bearing is bad, would a GRS I be the cure (does it come w/ a NEW bearing???)
thanks
alfred
Alfred is offline
post #5 of (permalink) Old 05-15-2000, 10:56 PM
GRS1 would only work if you have a bad bearing in the transfer case, not the transmission.
post #6 of (permalink) Old 05-16-2000, 12:54 PM
Before you drop your transmission, I would look into your U-joints. The problem (and sounds) that you are describing sound like what my brother and I had in our vehicles. My brothers would make really crappy sounding noises like something was scrathcing the crap out of his tranny. He was about to pull it all apart again, but first he checked the U-joints on his drivelines and that was the problem. So I would check them first. Even though it may seem like a pain in the butt if it ends up not being the problem, it's a lot better than having it be the other way around (drop tranny and it was relly the U-joints.) Plus it's not a bad idea to replace them every once in a while, especially if they are the originals. That's just my opinion though, maybe it will save you a lot of trouble in the end. Good Luck.
Remember the first rule in the Mountain Man Handbook: It's a long way to the hospital.
