Engine noise question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-30-2003, 09:27 PM
slugbutt
I noticed yesterday a noise coming from my engine. I have not had time to try and pinpoint where the noise is coming from.
It sounds like if you threw some rocks in a dryer and let them tumble around. I listened the best I could and it sounds as if the noise is coming from around the alt. water pump area. i was thinking it might the water pump about to go out. The fluid level is fine and I did not notice any leaking around the pump.
I drove it today on the highway and in the city. The engine never ran hot and with the weather we have had here lalely I had to turn on the heat this morning and as usual it about ran me out of the Samurai. So there are no leaks, that I can tell and the engine is not runnong hot.
I also noticed I had no loss of power and the Samurai is actually running the best it ever has since I have owned it. Was cruising at 75 mph today and didn't even realize it.
On purpose I would have it in the wrong gear to see if it would not pull a hill but it did fine.
The only things I have done lately was change the oil and the oil filter. I also did the heater box clean out. Where you cut a hole in the side above the heater box and suck out all the crap in there. Could that have done anything?
Right now it is just an annoying noise but I don't want an annoying noise to turn in to a pain in the wallet.
If it is the water pump how hard are they to c [img]images/graemlins/confused.gif[/img] [img]images/graemlins/confused.gif[/img]hange? Again detailed instructions would be greatly appreciated.
Thanks for the advice and opinions.
Marc
post #2 of (permalink) Old 05-30-2003, 09:40 PM
Re: Engine noise question
First , check the fan clutch for wear or wobble, then move to the water pump and check it's bearings for wear . After that , it could be either the timing belt cover or the lower belt sprocket is loose and eating the end of the crank off .
Sarge
Sarge is offline
post #3 of (permalink) Old 05-31-2003, 12:04 AM
Check the Alt bracket for cracks also. Hi frequency vibrations can destroy these. The cracks can
be rattleling
outlawmws is offline
