FI conversion - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-27-2003, 09:09 AM Thread Starter
FI conversion
I would like to convert my 86 Sammy with 1.6L engine to FI. I currently have the 1.3 carburated intake manifold on it. Now to do the conversion what would I need. From a 1.6 FI engine I would need
1) Complete intake manifold
2) Wiring harness
3) Computer
4) external fuel pump (not sure of PSI)
From what I have read to date this is the list. Is there something else that I am missing? Anything else I need?
Thanks
Lil_Mudder is offline
post #2 of (permalink) Old 05-27-2003, 11:19 AM
Re: FI conversion
FI fuel filter
High pressure fuel hose double clamped...
L8R
billybob is offline
post #3 of (permalink) Old 05-27-2003, 11:31 AM Thread Starter
Re: FI conversion
I am going to start calling around to see if junkers may have the parts I need. Now my question is... What years are compatible. Are they all interchangeable? If I have an 89 1.6L engine will any intake manifold that is meant for FI tracker/sidekick fit?
Thanks
post #4 of (permalink) Old 05-27-2003, 11:41 AM
pugrocker
Re: FI conversion
I did the same conversion - I suggest that you use a FI system from an 89-90 Kick / Track b/c you will not have to deal with the VSS conversion - just a bolt on affair.
For a fuel pump I used a NAPA # TFP2P74028 [Electric In-Line Type] and a Mallory 160 Series Fuel Filter (the stock fuel filter is a not a high flow unit and is designed for a carb although a lot of people still use them) - double clamp all lines and if money allows I would suggest that you change all the fuel lines to high pressure FI specific lines. I also recommend that you use a relay to fuel pump to ensure that it gets full power.
HTH [img]images/graemlins/40BEER.gif[/img]
post #5 of (permalink) Old 05-27-2003, 11:43 AM
pugrocker
Re: FI conversion
....and BTW if you need it I have an extra ECM for a 89 - 90 Kick / Track. PM me if you are interested or have any questions.
post #6 of (permalink) Old 05-27-2003, 01:34 PM Thread Starter
Re: FI conversion
I don't suppose anyone could tell me where I could find a step by step on doing this conversion.
Thanks
post #7 of (permalink) Old 05-27-2003, 03:48 PM
Brown29's Avatar
Re: FI conversion
I think you'll also need the efi distributor, the map sensor located on the firewall, and for some year models, the vehicle speed sensor.
Brown29 is offline
post #8 of (permalink) Old 05-27-2003, 06:58 PM
Re: FI conversion
Don't forget one of the most important Items...the FSM for the year your using.
As for compatibility (for 8v's), 89-90 can swap components, 91-93 can swap components and 94-95 gets a little fuzzy but seems compatable.
Also, It does not matter if the donor is from an Automatic or Manual transmission.
whazoo is offline
post #9 of (permalink) Old 05-27-2003, 09:31 PM
Re: FI conversion
Heres your step by step for the 89-90 FI conversion with wiring info. If you need pictures I can email them to you.
post #10 of (permalink) Old 05-28-2003, 08:07 AM
Re: FI conversion
This WILL interest you:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33553
I also have the COMPLETE systems that are not yet modified. E-mail me directly if you have any Q's.
Sean DeVinney
[email protected]
aftermarket4x4 is offline
