2-wheel low without modification?? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-12-2000, 09:23 PM Thread Starter
Does it hurt anything to put the transfercase in 4-low without locking the hubs? The reason I ask is because I just installed a rear locker and realize I won't need 4-wheel as often, but could use the low gear. Zuk on
I understand your jeep thing, I just don't care !!
ZuksRule is offline
post #2 of (permalink) Old 04-13-2000, 07:08 AM
mike shannon
Re: 2-wheel low without modification??
i do it every now and then but would not recomend it because you are spinning the axles on some brass bushings, that are not made to work as bearings,hope it helps mike.
87,88.5 spoa,32.5x11.5 5.12 f&r and the rx7 motor is at the shop hope to get it in soon.
post #3 of (permalink) Old 04-13-2000, 09:45 PM Thread Starter
Thanks for clearing that issue up
ZuksRule is offline
post #4 of (permalink) Old 04-13-2000, 11:15 PM
can you elaborate on the brass bushings?
is this a trait of Sami axles only or all 4wd front axles?
thanks for clarifying
OzarkJeep
77 CJ5, in a bunch of sanded and primered pieces
ozarkjeep is offline
post #5 of (permalink) Old 04-14-2000, 04:54 PM
mike shannon
if you pull off the hubs you will see where the axle goes through the brass bushings they are loose fitting with a pattern pressed in it,looks like it is for holding grease. mike
post #6 of (permalink) Old 04-14-2000, 05:34 PM
but its a floater axle, the weight of the truck isnt on the shaft right?
are you just worried about the shaft getting nicked up?
Ive done this for years in my JEEPS, usually when extracting or towing on dry pavement to either ease the automatic, or easy on the clutch
ive never had any problems.
My opinion is dont make any highway trips in 2wd low range and youyll be fine!
OzarkJeep
