two footed carb - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-05-2000, 10:24 PM
two footed carb
i have two sams one runs up nice when you floor it you can hear it open up and suck gas the other is flat it runs good but its like the carb donsent open i had this problem with a recently rolled sam itryed but couldent figure it oh and ilearnd to never build my own steering link thanks
Never feed a big dog cheese
post #2 of (permalink) Old 04-06-2000, 12:30 AM
Re: two footed carb
Need more info is gas mile used on flat carb higher or lower?
post #3 of (permalink) Old 04-06-2000, 07:43 AM
Re: two footed carb
to your reply the flat carb gets alot better gas milege but hope that helps . hey i seen abumper sticker on ajeep it was hard to read because it was upside down it said if you can read this roll me over he he
post #4 of (permalink) Old 04-07-2000, 01:52 AM
Re: two footed carb
87-88 Sam stock 2 -barrel down draft Carb
Sam carb when operating correctly is very fine device when
operating as designed. Suk motor spent many years developing
this carb there is none better to found anywhere for vehicle.
This carb is only some what complex part on a Sam. It has multi
stage operation, ECM fuel/air ratio computer metering control
with a vac default over ride
See Suk motor manual operation is well defined.
Answer:
Flat operation you mention indicates ECM and carb plunger is
working to control correct fuel/air ratio lean and good.
Old standard carb operation action indicates ECM and carb
plunger is in up positon not working fuel/air ratio rich.
Rave:
Suk designers go far beyond others to built carb meet emissions
standards and yet still operate or revert to old type standard
carburation if ERG emissions system failed, all ECM computer
feedbacks failed. In fact you could rip out computer rip out and
carb tubing, direct wire fuel cut off valve and add vaccum advance
start Sam up and drive this thing away, try to do this on some
other late 80s or 90s car...not
Tip & history
Good tip here if want power and full economy all you have to do
make sure your Suk carb is work correctly. Got OSP warning slow
Suk down on way to Miami off road or pay. I only know one speed
70 and faster, flat out like a lizard, me dumb.
I will never feed a big dog cheese
