Clutch Replacement - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-09-2003, 08:51 PM Thread Starter
87zuke's Avatar
Clutch Replacement
I started replacing my clutch and the bolts on the driveshaft are not cooperating. [img]images/graemlins/crybaby.gif[/img] Should I just snap them off or WD40 'em and hope for the best? The only driveshaft I need to take off is the short one between the trans and T/C correct? Anything else I should know that would help would be appreciated. TIA. [img]images/graemlins/thud.gif[/img] Jim
87zuke is offline
post #2 of (permalink) Old 05-09-2003, 10:26 PM
Re: Clutch Replacement
Try PB blaster, brake fluid, liquid wrench, in decending order of effectiveness. WD40 isn't that great as a
penetrant.
if you have to snap them off there probably not worth reusing anyway.
outlawmws is offline
post #3 of (permalink) Old 05-09-2003, 10:33 PM
Heat the nuts a bit , that factory lock tite works real well ....
Sarge
Sarge is offline
post #4 of (permalink) Old 05-11-2003, 10:06 AM Thread Starter
87zuke's Avatar
Thanks for the replys. I'm going to head back out and try some more. The short driveshaft is the only one that needs to be removed? The T/C can stay? Thanks. Jim
87zuke is offline
post #5 of (permalink) Old 05-11-2003, 10:48 AM
The transfer case can stay in there , it's a lot easier if you grind a notch in the crossmember on the driver's side next to the tranny mount . You'll see where when you attempt to remove the trans , it's a tight fit and it will come out if the motor is angled just right . Make sure to put a block behind the distributor drive so you don't break it on the firewall when the trans mount is removed . Also , it's a good idea to drain the trans before hand or you'll get a bath in gear oil . Most aerosol can lids such as carb cleaner will fit the trans output seal real well to keep the drips on your face to a minimum ....
Sarge
Sarge is offline
