Three Way Solenoid Valve - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-25-2000, 04:38 PM
Anyone know an inexpensive place to get hold of the TWSV that sits high and at the back (engine firewall side) of carb?
Also there is one that sits low (just above water pump) that the little plastic bits/ vacuum hose couplers have broken off.
Once again appreciate your help. I am not lazy I just live 80 miles from tiny Flagstaff AZ.
post #2 of (permalink) Old 01-25-2000, 05:56 PM
Re: Three Way Solenoid Valve
To put on a new vacume hose barb cut off a 3/8 length of brass tube from a ball point pen. Use tube to replace broken fitting gluing it in place.
Has worked for me.
post #3 of (permalink) Old 01-26-2000, 10:43 AM
Looked at a number of pens at work none have an obvious brass tube- are you refering to the end where the ball is? Or is there a special kind of pen out there?
Also did you use epoxy for the glue? Reason I ask is that I tried superglueing the old broken plastic part back on and it did not work. Then I opted for some epoxy which also did not work- maybe it was too old- thw wife gave it to me you see.
Thanks for the help.
post #4 of (permalink) Old 02-03-2000, 12:44 PM
zukikid
had the same problem with the one that bollts to the head...53.50 through the dealership,5 bucks at local junk yard.one thing ,when i called them up loking for the part they said they didn't have it.i got mad because they had sammys with complete engines.so call junkyard around where your at and ask if they have sammys with engines still in the truck,if they say yes ...go there and say "i'm looking for a part and don't know what it is ,can i look for it and if i find it will you sell it to me ?they will say yes and go pull the little bugger off and bring it to them and they will probabely sell it for 5 bucks:-) good hunting
