water in transfer case - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-24-2000, 09:07 AM
ok i dont have a shift sheet in it (do i need it) any who some of the holes i go through are deep and water gets in in there
how do you keep it out
is there a boot like on the transmission
post #2 of (permalink) Old 01-24-2000, 11:15 AM
Re: water in transfer case
There is a boot, but I had the same problems,I just took some duct tape and used several small pieces that were easy to work with and covered the top where the locking ring is and then pushed the rubber boot down over to where its supposed to be and hadnt had any problems since.
post #3 of (permalink) Old 01-24-2000, 11:51 AM
The sheet seems to be a bearing surface that gives low friction while preventing ware of metal parts of shift lever and housing. Whithout the sheet the transfer case shift lever sets about 1/4 inch lower. Then the flat spot on the shift lever is not ingaged in the shift rods notches but a round section is in the notch. Then the sift lever can cross over to the hi/low shift rod's notch while still in 2 wheel drive locking up the transfer case. Lock up can't happen if the right parts have been removed from the transfer case.
There should be a lower boot to keep out water. Duck tape can help. Extending a vent hose above maxamum water level helps.
post #4 of (permalink) Old 01-24-2000, 06:39 PM
thanks i'll see if i cant round up a boot from somewhere
post #5 of (permalink) Old 01-24-2000, 10:21 PM
Get a rubber boot!
Then vent your tcase breather located on top of the tcase to a higher location. Water in the tcase will destroy your bearings. An easy fix now will save you lots of headache down the road.
http://www.rocky-road.com
