engine idle speed - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-21-2000, 11:09 PM
engine idle speed
Alright I've replaced all vac lines,rebuilt the stock carb,fast idle mark is almost perfect,changed pcv valve,changed dist.,basically done everything I know to do but every time its cranked it will automatically rev up to 4 grand and then die.Just rebuilt the 1.3 done so much to make it run better,and now this.Has anyone fought this problem yet.Could it be the computer is screwed up?I've ordered a pony by the way.
post #2 of (permalink) Old 01-21-2000, 11:43 PM
Re: engine idle speed
I had a problem with the carburetor after rebuilding an engine. In my case the needle valve was stuck due to dried varnish deposits. While things are getting worked on during a rebuild often the carburetor is setting at strange angles and even the fuel gets dumped from the float bowl. Then normal deposits can dry in strange places. Some spray carburetor cleaner and blowing out passageways with LP air can sometimes fix without doing a total rebuild of the carburetor.
post #3 of (permalink) Old 01-22-2000, 07:57 AM
I just rebuilt the carb.everything was cleaned,the needle valve was replaced,all o-rings.The best i can tell the bottom butterfly valves in the venturi are opening wide open at start then shutting off.
post #4 of (permalink) Old 02-09-2000, 01:36 PM
zukikid
zuki kid here ...shot in the dark,get your zuk running,and disconect the throttle cable from its bracket but not the carb ,if rpms drop you need to reindex your cable .p.s adjust it again when the engine is hot .just trying to help zukikid
