proper way to bleed samurai brakes? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-17-2003, 08:24 PM Thread Starter
i have a 93 samurai and just installed my YJ suspension kit. i noticed that the rear passenger side drum doesnt have a bleeder valve on it but there is a bleeder on the proportioning valve. do i have to bleed the driver rear first then go straight to the front passenger side or should i bleed the proportioning valve after rear driver side drum?
Ag_xterra is offline
post #2 of (permalink) Old 03-18-2003, 08:25 AM
Re: proper way to bleed samurai brakes?
I've had the best luck bleeding the proportioning valve first then the drivers rear ,passenger front,driver's front.
After we bleed the brakes on the samurai we always go ride on a gravel road by my house (wask board road) then bleed the brakes again,really helps get all the air out the system and give a good pedal feel again.
DOABLE is offline
post #3 of (permalink) Old 03-18-2003, 10:05 AM
same as above but
i have found that if you take a jack and raise the right rear tireup higher tha the left and make sure its lower than the m/c it wil bleed much easier. if you can cap off the line did it first at the right rear than do your swao when you are finished runing th lines leave it un hooked at the drivers right make sure you have the m/c full of fluid and let it gravity bleed while it is leaking hook up to the rear slave cylinder after it drips for afew sec. close it up fill up the fluid then start bleeding the brake lines
hth
charles
GA_ZUKI is offline
post #4 of (permalink) Old 03-18-2003, 02:10 PM
one thing i have noticed is the rear wheel cylenders the bleed hole isnt on the top of the cylender i have better luck with mine if i park on a small hill nose down now i all i have to do is get the rear brake ajusters working right again
szki272 is offline
